SolaraGuy.com • View topic - Button on Console?
Button on Console?
Button on Console?
Postby Teamroper » Thu Jul 29, 2010 7:34 am
OK, I am going to show my ignorance about this vehicle but here goes. I have a '99 Solara V6 with an automatic trans. Just in front of the shifter in the middle console is a 1/2" X1/2" hole that appears to have possibly had a "plate" on top of it. In this hole is a rubber button that will depress upon pressure however nothing shows up on my dash or anywhere else to show that this may be an overdrive engagement or "turbo shift" button. Does anyone know what this is for and was this a location for an overdrive button for certain models? I have also pushed this button while driving with no effect. Thanks for any info.
Teamroper
Re: Button on Console?
Postby solara90 » Thu Jul 29, 2010 9:09 am
all that does is disengage the lock on your shifter so you can shift out of park with out your keys
02 solara 2az
solara90
Postby crispone » Thu Jul 29, 2010 10:01 am
solara90 wrote:all that does is disengage the lock on your shifter so you can shift out of park with out your keys
Or you may HAVE your keys, but NOT want to start the engine... i.e.: put it into neutral, etc... and in some cases, to remove interior panels (such as radio install...) but not fire the engine, etc...
Postby TheGreenDutch » Thu Jul 29, 2010 12:39 pm
Its called a "Doomsday" button.
TheGreenDutch
Postby solara90 » Thu Jul 29, 2010 1:01 pm
well its actually a secret self distruct button, yours must not be working :-)
02 solara 2az
solara90
Postby 99BlackSandv6 » Thu Jul 29, 2010 9:03 pm
Yeah, its to disable the shift lock mechanism. As 90 and crisp said. There should be a small cap
that covers it. It just pops off, so someone probably lost it. You might find it under your seat.
Oh, and your overdrive button is on the side of the shifter, it's marked O/D.
