SolaraGuy.com • View topic - driver seat problem
driver seat problem
driver seat problem
Postby thenewguy » Sat Aug 14, 2010 5:57 pm
alright so this just happened today. My seat wont "click" to the upright position allowing the seat to move forward and backward. not sure how to fix that kind of problem.
have a gen1 solara sev6 5spd. thanks guys
thenewguy
Re: driver seat problem
Postby TheGreenDutch » Sun Aug 15, 2010 3:45 pm
Yup mine too. Moves on one side of the track only so much back and forth like somethings stuck but I can't find it...:(
on a side note check the fuses and connections to see if they have come apart or broke...
TheGreenDutch
Postby thenewguy » Sun Aug 15, 2010 10:40 pm
nono u misunderstood. my seat cannot stay at the up-right position and can only lock in place at the reclined all the way back position
thenewguy
Postby yaddadaimsayin » Mon Aug 16, 2010 12:05 am
well that should make driving quite entertaining... and dangerous. good luck
Postby dug320 » Tue Aug 17, 2010 6:55 pm
You have to move the seat around until the catch finds the slot. The other issue is that the catch mechanism is worn out and may need to be replaced. I have seen a few in the yards as you have described.
dug320
Postby thenewguy » Tue Aug 17, 2010 9:40 pm
yea i took my seat apart and noticed that it wasnt catching. assuming i call toyota up they'll only sell it as a whole. so ill end up spending 500 bucks for a catch. pshhh. OFF to the JUNKYARDS!!!
thenewguy
Postby AnglerfisH » Thu Aug 19, 2010 8:33 am
Agreed, junkyard run! I had the seat frame for the back fail in my old '89 Maxima and Nissan wanted $1200 for a new seat/frame assembly. No way! Went to a junkyard and got a whole seat for $75!
Philips X-treme Power halogens
K&N drop filter
AnglerfisH
Postby thenewguy » Mon Aug 30, 2010 11:34 am
got it fixed! WOOO
thenewguy
