SolaraGuy.com • View topic - Autotrans question...Going from Park to Drive
Postby MetrowestLara » Wed Aug 25, 2010 11:59 am
I have a 1999 Gen 1 SLE V6 Solara with an automatic transmission. I noticed that when moving the gear shift from Park to Drive that it is very stiff. When it's in Drive I can push the gear shift lever forward and the indicator on the center console with almost go up to Neutral. I was wondering if guys with similar year cars experience the same thing. Is it possible I'm having transmission trouble or is it just the gear shift linkage being a little messed up. Appreciate any comments.
MetrowestLara
Re: Autotrans question...Going from Park to Drive
Postby 99BlackSandv6 » Thu Aug 26, 2010 7:09 pm
The lever needs to be adjusted.
Postby MetrowestLara » Thu Aug 26, 2010 7:57 pm
Thanks. I'm not much of a mechanic. Do you know how to do that and are you willing to share or point me to some instructions?
MetrowestLara
Postby Mole » Thu Aug 26, 2010 11:01 pm
open up the area and clean it... i assume someone spilled soda in there or something.
Postby 99BlackSandv6 » Fri Aug 27, 2010 7:49 am
See page AX2-69. Halfway down the scroll bar.
http://www.scribd.com/doc/6004125/a541e ... -Transaxle
Postby MetrowestLara » Fri Aug 27, 2010 8:19 am
Thanks for the link. I will make the adjustment and hopefully it will solve the problem.
MetrowestLara
