SolaraGuy.com • View topic - Solara starting weak...
Postby SPICA1750 » Wed Aug 25, 2010 7:00 pm
My 2000 solara starts weak sometimes..does anyone elses do that. like it starts fine but others it sounds weak and trying to start. :roll:
2000 Toyota Solara SE<aftermarket exhaust>
1995 BMW 525i..(sold)
SPICA1750
Re: Solara starting weak...
Postby crispone » Wed Aug 25, 2010 7:15 pm
SPICA1750 wrote:My 2000 solara starts weak sometimes..does anyone elses do that. like it starts fine but others it sounds weak and trying to start. :roll:
My '04 has also begun to do this! A full charge on the battery does not seem to make much difference. I am wondering if it's the starter or battery is just becoming "spent"? I have worked it very hard and for MANY miles and hours of high-current draw through multiple amps...
Jury is still out in my case...
Postby SPICA1750 » Wed Aug 25, 2010 8:07 pm
My friend told me it could be the starter...my battery is pretty new i think.. its weird cause i dont leave anything on for the battery to go weak..
hmm! :crazyeyes:
SPICA1750
Postby mac-phisto » Fri Aug 27, 2010 8:13 am
check your battery terminals for corrosion. PB blaster & a wire brush works wonders on them. the wires themselves sometimes become brittle & break as well. if you have a little play, you can strip them back & re-terminate them. otherwise, you might have to replace the cables.
mac-phisto
Postby SPICA1750 » Fri Aug 27, 2010 2:20 pm
mac-phisto wrote:check your battery terminals for corrosion. PB blaster & a wire brush works wonders on them. the wires themselves sometimes become brittle & break as well. if you have a little play, you can strip them back & re-terminate them. otherwise, you might have to replace the cables.
nah..my dad and i just did service and cleaned them like a month ago
SPICA1750
Postby kingkakyle » Fri Aug 27, 2010 5:56 pm
maybe the battery is just weak
even if its new, something could be draining it
mine does that, i have a stock battery, my HIDs drain it alot, as well as my navi system and all the peripherals i installed
Postby crispone » Sat Aug 28, 2010 10:51 am
kingkakyle wrote:maybe the battery is just weak
Peripherals, yes. HIDs, should not drain a lot. They draw LESS current that conventional Halogen bulbs, with only the "spike" for an instant when the ballast "kicks" 'em on. (I'm pretty sure...) They also run COOLER than conventional bulb technology, I've read... but correct me if I'm mistaken.
I think "weak battery" is likely my situation. 6 years on original battery with the heavy current amp draw on mine and I'm pretty sure I'm ready for a new one. We'll see if that take care of the issue for me!
Postby MisterTedster » Sat Aug 28, 2010 11:37 pm
It could be that your alternator is not charging as much as it should. I had to replace mine because my amps were drawing too much power and eventually burned out the alternator.
02 SE V6
MisterTedster
Postby crispone » Sun Aug 29, 2010 7:08 am
MisterTedster wrote:It could be that your alternator is not charging as much as it should. I had to replace mine because my amps were drawing too much power and eventually burned out the alternator.
That's my #2 suspicion. Either way, my battery is definitely "aging" and I may place a fresh one and see if the symptoms return. Then it's likely the alternator. Sometime, I'll pop in a local car place and check it with a load to be sure...
Postby SPICA1750 » Sun Aug 29, 2010 11:46 am
thanks guys for your help :)
SPICA1750
Postby crispone » Sun Sep 19, 2010 4:35 pm
Just a quick (and late) follow-up on this...
As suspected, changed my battery and now the car "pops" almost instantly, and has continued to show NO signs of any starting difficulty since. I guess 100k+ miles and 6+ years of use has finally done the "stockie" in.;)
Postby 02slera » Sun Sep 19, 2010 5:06 pm
advance auto or autozone will check most cars battery and charging system for free, just go in and ask. the battery has to test "good" for the alternator to be tested. -just general info for anyone.
2002 Solara SLE v6
02slera
Postby SPICA1750 » Sun Sep 19, 2010 7:10 pm
yeah i think i might have it checked out tomorrow..
SPICA1750
Postby kenny6683 » Mon Sep 20, 2010 7:28 am
this happened to me this past weekend too. i think my HID lights plus W7 juiced all the power that old ass battery had left to it. bought a new one and back to normal but i will use a volt meter today to check alternator...it could also be shot. a new battery will make car run again but u should still check alternator especially now before winter comes
kenny6683
Postby TheGreenDutch » Tue Sep 21, 2010 9:15 am
02slera wrote:advance auto or autozone will check most cars battery and charging system for free, just go in and ask. the battery has to test "good" for the alternator to be tested. -just general info for anyone.
AutoZone is the best. Do this for free code check as well.
TheGreenDutch
