SolaraGuy.com • View topic - ABS Code 38
ABS Code 38
ABS Code 38
Postby user99 » Sat Aug 28, 2010 10:17 am
I have an active ABS light and diagnosed it several times and it comes up with code 38 (check sensor, connections, wire). Since I can't really check the wire itself, I checked the connections on both ends and they were solid but I still get the light and same code after attempting to reset. Anyway, I was just wondering if there was anything else to check before I order a new sensor harness. Also is there any particular brand that is better for OEM?
Thanks
99 Solara SLE V6, Automatic
user99
