SolaraGuy.com • View topic - clutch problem???
clutch problem???
clutch problem???
Postby thenewguy » Thu Sep 16, 2010 10:10 pm
So once and a while i get a problem while i drive. When i put the accelerator pedal all the way to the floor while driving around town, the car's rpm's rise as if my clutch isn't all the way out. (happeneing while my foot is not even touching the clutch, mat isn't problem either :drinking: :drinking: ).
So what do you think is the problem? Clutch? :bad-words:
thenewguy
Re: clutch problem???
Postby 1gSE » Fri Sep 17, 2010 1:04 am
clutch is slipping, time to replace it
Solara-M62 @ 5.5psi
1gSE
Postby DSM_Lara » Fri Sep 17, 2010 4:45 am
^^^ that sounds like your issue.
DSM_Lara
Postby ftw » Fri Sep 17, 2010 5:22 am
^^^^Yep...I agree with the two above. Classic clutch slipping symptom.
New Daily: 2005 Corolla XRS
SOLD: DWP 1999 SE V6| Eibach/Tokico| Super Pro Dogbone Bushings, FSB Bushings| Energy Suspension Front Control Arm Bushings| Injen Intake
ftw
Postby thenewguy » Fri Sep 17, 2010 9:31 pm
rawr... mmk mind as well go toward PERFORMANCE CLUTCH!!!
thenewguy
Postby thenewguy » Fri Sep 17, 2010 9:33 pm
which clutch would u guys reccomend? OEM exedy? stage 2?
thenewguy
