SolaraGuy.com • View topic - Trans Fluid
Trans Fluid
Trans Fluid
Postby Night_Wolf » Tue Oct 12, 2010 7:37 pm
I'm running a 1999 Toyota Solara V6 transmission (E15X? i think) on a 3SGTE in a Toyota Celica ST pushing apprx 280 hp and the shifting is a little bit rough and clunky. What kinda of fluid would you guys recommend to use. Im currently using mobil synthetic (i forgot the weight atm), anybody recommend anything in particular?
Night_Wolf
Re: Trans Fluid
Postby dug320 » Wed Oct 13, 2010 11:49 am
I would suggest replacing the ATM fluid. Mobil is as good a the others in my opinion. There is nothing more than can be done.
dug320
Re: Trans Fluid
Postby Eye8Pussies » Thu Oct 14, 2010 8:10 am
GM synchromesh has always been highly recommended for trannys that may be shifting a bit harsher than they should
Re: Trans Fluid
Postby mig0s » Thu Oct 14, 2010 8:17 am
Use the all synthetic Red Line MT-90. Best transmission fluid you can get. Trust me. Also all the drifters and racers here use it. Btw the transmission is a E153.
mig0s
Re: Trans Fluid
Postby Night_Wolf » Thu Oct 14, 2010 10:51 am
mig0s wrote:Use the all synthetic Red Line MT-90. Best transmission fluid you can get. Trust me. Also all the drifters and racers here use it. Btw the transmission is a E153.
Cool thx!
dug320 wrote:I would suggest replacing the ATM fluid. Mobil is as good a the others in my opinion. There is nothing more than can be done.
What is ATM fluid? Do you mean ATF, and if so its a 5spd manual.
Night_Wolf
Re: Trans Fluid
Postby dug320 » Sat Oct 16, 2010 5:50 pm
I meant ATF. I think ATM is something banking related.
dug320
