SolaraGuy.com • View topic - weird v6 auto transaxle problem
Postby ozzycat93@yahoo.com » Mon Nov 22, 2010 8:05 pm
I have a 1999 Solara SLE V6 with an auto transaxle and it has a problem that i cant seem to find that anyone else has. On a flat road running in 4th gear at 40-47mph the tranny starts slipping and the car jerks, it only does it when at absolute constant speed and there is no change in the rpm. I have also turned :bad-words: off the O/D to help, but it still slips at 39-41mph at constant speed with the accelerator barley pressed or the cruise is on.
I really need to know what is going on, i have taken out some of the tranny fluid cause it was high and still the problem persists.
Last edited by ozzycat93@yahoo.com on Wed Nov 24, 2010 8:18 am, edited 1 time in total.
ozzycat93@yahoo.com
Re: weird v6 auto transaxle problem
Postby 02slera » Tue Nov 23, 2010 4:22 am
are you sure its not a mis fire?
last time you changed spark plugs? wires?
2002 Solara SLE v6
02slera
Postby ozzycat93@yahoo.com » Wed Nov 24, 2010 7:32 am
ok, I will look into it the plugs and wires condition, but why would it not happen at higher and lower speeds? it has never happened cruising on the highway at 60mph? reason i ask is i am about to replace the timing belt water pump hoses ect... and i dont have a lot of money to replace them unless i am sure
ozzycat93@yahoo.com
Postby TheGreenDutch » Wed Nov 24, 2010 11:00 am
what color was the fluid in the trans you took out? I had an open wire on my coil packs arching that made my car buck at start up...look into that. End with the trans its the most expensive to fix :(
TheGreenDutch
Postby ozzycat93@yahoo.com » Wed Nov 24, 2010 3:43 pm
the fluid is only 4000 miles old, and it was normal color but a little murky. I have never had it buck at start up, but running on regular fuel, the exaust does smell funny...
ozzycat93@yahoo.com
Postby ozzycat93@yahoo.com » Thu Nov 25, 2010 11:27 am
color was normal, but murky and it is only 4000 miles old, i never had the car buck at startup, its starts normally and shifts normally in all gears, idle is fine as well, and yeah tranny problem= big bucks =(
ozzycat93@yahoo.com
Postby dug320 » Thu Nov 25, 2010 6:00 pm
Does it jerk or feel like a transmission slip with a slight loss of power?
dug320
Postby ozzycat93@yahoo.com » Fri Nov 26, 2010 2:17 pm
yes it does. but the engine noise doesnt change.
ozzycat93@yahoo.com
