SolaraGuy.com • View topic - Solara drivers Airbag Icon came on without any impact
Postby Danillo17 » Wed Dec 22, 2010 7:48 am
My drivers side icon went on for no apparent reason. It stays on solid. It doesnt flash. I used the electrical outlet for a tire air compressor and i moved the passenger seat over the weekend. That is the only thing I can think of that happened unless a wire came loose. I did several searches and followed the TC/AB drum. It flashes a 54 code sequence but goes back to solid light after the ground is removed. Anyone know any tricks to reset it to go out? Any other advice? Thanks in advance.
2002 Solara SLE Convertible
Danillo17
Re: Solara drivers Airbag Icon came on without any impact
Postby Danillo17 » Thu Dec 23, 2010 8:01 am
If anyone can help me get this light off they get naked pictures of my girlfriend. Just a joke..well maybe not. Thats how bad I want this light gone, lol
Danillo17
Postby Mole » Thu Dec 23, 2010 9:23 am
1. do you have you seatbelt on?
2. how long do you wait after starting the car before moving?
Postby Danillo17 » Thu Dec 23, 2010 12:06 pm
I usually dont have the seat belt on when attempting to get rid of the code. It flashes a 5 than a 4. The previous owner told me it once came on when he had groceries in the passenger seat but then went off. I have tried the ab/tc method with speaker wire several times. It gets the cruise and other lights to flash. It gets the air bag icon to flash but after the wires are removed the icon remains lit.
I dont usually drive the car while trying to remove the icon. In general I wait a few seconds from start up to driving.
I used a air compressor in the electrical outlet this weekend before the air bag light came on the next day. I also moved both seats a bit on Saturday before the light came on the next day.
From searching online the code 54 may indicate something with the passenger seat
Danillo17
Postby 02slera » Thu Dec 23, 2010 1:30 pm
yea i would suspect some loose connection near the passenger seat.
my airbag light in the dash came on a few days ago, i thought "oh crap here we go" but to my surprise, the next day when i got in the car and started it, the light went off and has been normal ever since. this leads me to believe that it is reset every time the car is turned off, but i dont know for sure. it never hurts to try disconnecting the negative battery terminal for a few minutes and then hooking back up. i would definitely check all wiring under the seats or even up under the dash, just turn everything to off and start moving things around and then start the car and see if you get lucky lol
2002 Solara SLE v6
02slera
Postby Danillo17 » Sat Dec 25, 2010 9:20 am
My light has stayed on for 6 days. What a pain in the neck. I have tried moving the seats several times and wiggling some things. No luck so far. Is there only that big yellow connector under the seat? Or are their more connectors? How does the seat belt pretensioner effect it? The tensioners on both my seat belts seem to be lacking a bit in how they return the seat belt.
Danillo17
Postby stringbean » Sat Dec 25, 2010 3:36 pm
mines been on for months! solid no flashes! would like it gone as well!
stringbean
Postby Danillo17 » Sun Dec 26, 2010 4:24 pm
Did you find the code reading for yours? Mine is a 5 then a 4 flash deal which seems to be something with the front passenger seat
Danillo17
Postby solara90 » Sun Dec 26, 2010 4:29 pm
Take the bulb out.
02 solara 2az
solara90
Postby stringbean » Sun Dec 26, 2010 5:52 pm
solara90 wrote:Take the bulb out.
I was thinking just that when i change my instrument lights to LED's lol
stringbean
Postby Danillo17 » Mon Dec 27, 2010 4:12 pm
I cant just remove the light. I plan to sell one day and cant have somebodies possible injuries on my conscious. Any other ideas?
Danillo17
Postby 02slera » Mon Dec 27, 2010 7:57 pm
does the car have the airbags in the sides of the seats?
mine does.
i would check all wires associated with that. careful, its usually recommended to take it to the shop for airbag issues.
but my car, i would disconnect the battery, un plug and re connect any plugs for the wires associated with the seats airbags and sensors. other than that, i would take it to the shop. i had a 99 ford explorer with an airbag light on in the dash and the dealer fixed it for less than $50 and told me it was something like a loose plug under the passenger seat. thats why i say check connections first, then take it to someone who has the means to troubleshoot this system.
2002 Solara SLE v6
02slera
Postby Danillo17 » Mon Dec 27, 2010 8:44 pm
Mine is a 2002. I believe it has side air bags but I dont know where those side wires are. All I tried to mess with was a big yellow plug. The plug seemed fine but the plastic clear round thing that connects to the seat seems loose
Danillo17
Postby 02slera » Tue Dec 28, 2010 8:13 pm
the side airbags are actually IN the seat.
2002 Solara SLE v6
02slera
Postby Toy1mzfe » Wed Dec 29, 2010 1:08 am
I had turn on on me when i drove through a puddle. I just reseted the ECU by removing the battery and stepping on the brakes for 15sec.
It was a slight malfunction, but it was fine after that.
