SolaraGuy.com • View topic - gen1.5 solara SLE V6 sway bars diameter
Postby feniks » Fri Jan 14, 2011 10:38 pm
can anybody post what are the diameters (in mm please) of both front and rear stabilizer/sway bars?
I'm trying to find right Energy Suspension bushings.
'02 Solara SLE 1MZ-FE/A541E Coupe .: Denso : Akebono SP : HIR :. @ 125k
'00 Solara SE 5S-FE/A140E Coupe .: NGK : Hawk HPS : Philips Xtreme : RC : Magnefine :. @ 79k
feniks
Re: gen1.5 solara SLE V6 sway bars diameter
Postby 02slera » Sat Jan 15, 2011 9:53 am
i think its 17mm front and 15mm or 16mm rear. but dont go buying anything based on that, anyone know for sure?
2002 Solara SLE v6
02slera
Postby feniks » Sat Jan 15, 2011 4:42 pm
thanks.
I am trying to find confirmation for this model, but it's not easy heh...
feniks
Postby cartang » Sat Jan 15, 2011 4:52 pm
Check the official aftermarket parts list by Midias , is there.
[IMG]http://i275.photobucket.com/albums/jj307/cartang1/007-2-1.jpg[/IMG]
Camry 99, 5sp manual, SC,CPE intake,OBX headers, Jim's fuel system,Walbro pump,Greddy exhaust,Exedy 1 clutch,Fidanza flyweel.
Camry 07, V6,TRD cat back,Fujita CAI, GS 430 rims
cartang
Postby feniks » Sat Jan 15, 2011 5:23 pm
cartang wrote:Check the official aftermarket parts list by Midias , is there.
a link please?
I cannot find what you mentioned.
feniks
Postby feniks » Sat Jan 15, 2011 10:00 pm
i think I found something:
http://www.vehix.com/car-reviews/2002/t ... ifications
Stabilizer Bar Diameter - Front (in): 0.67
Stabilizer Bar Diameter - Rear (in): 0.63
for SLE V6 that would make 17mm front and 16mm rear.
for SE 2.2L it would be 17mm front and 15mm rear, like this:
Stabilizer Bar Diameter - Rear (in): 0.59
it seems no store carries 17mm Energy Suspension bushing+bracket hehe... rear 16mm is common, but for fronts they mostly sell upsized diamters (18mm and up).
I guess I will get Moog bushing inserts all around and call it a day.
feniks
Postby cartang » Sun Jan 16, 2011 10:44 am
Ok go to subforum( in Solaraguy ) Aftermarket upgrade 1-15. gen Solara , look for the post
OFFICIAL GEN 1-1.5 AFTERMARKET PARTS LISTINGPosted:
cartang
Postby feniks » Sun Jan 16, 2011 4:13 pm
cartang wrote:Ok go to subforum( in Solaraguy ) Aftermarket upgrade 1-15. gen Solara , look for the post
if this is what you mean, then it doesn't help much as we are talking about STOCK/OEM bushing sizes, not aftermarket upgrades ...
viewtopic.php?f=2&t=37723
Whiteline (http://www.whiteline.com), (http://www.globalperformanceparts.com)
All Engines
Sway Bar Front (BTF38) 24mm
Sway Bar Rear (BTR39) 20mm
Front Springs (73119)
Rear Springs (78600A)
Strut Tower Brace (KSB508)
Energy Suspension (http://www.energysuspension.com)
99-03 All Engines
Front End Control Arm Bushing Set (8.3117)
Rear End Control Arm Bushing Set (8.3118)
Front Sway Bar Frame Bushings 18mm (9.5122)
Front Sway Bar Frame Bushings 19mm (9.5123)
Rear Sway Bar Frame Bushings 16mm (8.5120)
the best the stock setup can get is an Energy Suspension bushing insert (16mm) for rear sway bar on V6, so far I haven't found any polyurethane bushings for stock front application (17mm).
Other option is going with MOOG (federal Mogul) bushings, but they are rubber, maybe a little better over OEM.
feniks
