SolaraGuy.com • View topic - 02 solara SLE V6 muffler hanger question
Postby feniks » Sat Feb 12, 2011 8:17 pm
today when working on a few things in rear end suspension and brakes I found something odd around the muffler.
Part in question is the bracket for Exhaust Pipe Support or a Muffler hanger located right behind the rear right (passenger) wheel.
Here is a pic. It looks like it either got bent or dislocated or is detached? Also that hook thing (part of bracket) is rubbing on metal part sticking out of support.
Big picture here:
http://img593.imageshack.us/img593/4860 ... 114646.jpg
can someone shoot a pic of theirs or tell me what's wrong here? am I having a mismatched bracket frm some other model?
thank you.
'02 Solara SLE 1MZ-FE/A541E Coupe .: Denso : Akebono SP : HIR :. @ 125k
'00 Solara SE 5S-FE/A140E Coupe .: NGK : Hawk HPS : Philips Xtreme : RC : Magnefine :. @ 79k
feniks
Re: 02 solara SLE V6 muffler hanger question
Postby feniks » Mon Feb 14, 2011 8:05 pm
does anyone know?
feniks
Postby solaraqueen » Tue Feb 15, 2011 12:58 am
it looks broken, ask gregtrd, pm him....
solaraqueen
Postby 02slera » Tue Feb 15, 2011 4:54 am
ok ill go look at mine and post back....
my bracket looks the same but mine isnt pushed back that.
it sits about halfway between where yours is and centered.
will get a pic later if you want, just dont have time right now, off to work.
i think something is pushing your whole exhaust pipe toward the rear a couple inches, check all of those hangers, i believe if any one of the them is broken/ripped it could cause this. but its NOT supposed to be like that.
2002 Solara SLE v6
02slera
Postby feniks » Tue Feb 15, 2011 9:38 am
solaraqueen wrote:it looks broken, ask gregtrd, pm him....
thanks. will look into it deeper.
02slera wrote:ok ill go look at mine and post back....
thanks!
so basically the part is correct, just something is offset. I think someone in past may have hit the exhaust tip when backing the car up into something. so either the whole exhaust is moved toward front and brackets stayed in original positions or brackets moved forward and exhaust stayed in original position. looks weird I agree.
will check other hangers and brackets, there is quite a few of them total, but I think other suspicious would the one most far out (the other side of muffler).
in case I need to replace both muffler hangers if it starts bothering me too much, do you think I would need new hanger and bracket or justhanger or just bracket ... or new exhaust haha :)
feniks
Postby 02slera » Fri Feb 18, 2011 4:43 am
i think you need to find what is causing this issue, whether it be a broken hanger or bent bracket or bent exhaust, id be interested to see a pic of a different hanger on your car for comparison purposes, im wondering if all of your hangers are gonna show the exhaust slightly offset from where it should be or if its just one or two of them. but just going around replacing hangers and brackets randomly would be a waste imo. you have to pinpoint the problem.
2002 Solara SLE v6
02slera
Postby feniks » Tue Mar 15, 2011 10:32 pm
it was a bent and twisted bracket.
replaced with a new one and is all good :)
feniks
