SolaraGuy.com • View topic - cylinder location
cylinder location
cylinder location
Postby mettler » Tue Mar 22, 2011 9:54 am
can someone give me a layout of the cylinder numbers for a V6. I have a misfire in #6, but I am not sure which one that is.
thanks
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Re: cylinder location
Postby 1gSE » Tue Mar 22, 2011 10:05 am
firewall
135
246
radiator
Solara-M62 @ 5.5psi
1gSE
Postby ThurzNite » Tue Mar 22, 2011 11:34 am
Thank goodness it's one of the easier ones to get to! Good luck problem solving. Do you have a code to go with it?
Dr J
ThurzNite
Postby mettler » Tue Mar 22, 2011 12:14 pm
yeah, you ain't kidding about being one of the easier ones.. I was really hoping that it was one of those.
I have two codes -
P0300
and
P0306
I know one is the misfire on #6 and the other, I think, is a random misfire. I think one gives a cylinder # and other doesn't, but I think they are related. I am leaning towards the coil because as the car warms up the problem seems to lessen of not go away entirely. When I did the timing belt, the plugs/wires were changed.. even tho that was a little while ago.
mettler
Postby ThurzNite » Tue Mar 22, 2011 12:51 pm
It's been a long time since I've done my spark plugs (50k), but doesn't 1 ignition coil fire 2 spark plugs? If that's the case, there should be another code for another cylinder? Or do you think the p0300 is it?
Anyways, I'm going with Spark Plug. When was the last time that was changed? Keep us updated!
Dr J
ThurzNite
Postby 1gSE » Tue Mar 22, 2011 12:52 pm
Move the coil to another cyl, reset the ecu and see if it comes back on the other cyl.
Solara-M62 @ 5.5psi
1gSE
Postby mettler » Tue Mar 22, 2011 1:06 pm
one of the codes was 'random misfire', and the other was 'misfire on #6'. It was definitely a random misfire - as it really only happens when it is cold out - which is why I am leaning towards the coil. I will swap the coil to another cylinder and get the ECU reset and see what happens - good idea.
thanks
mettler
Postby mettler » Sat Mar 26, 2011 2:05 pm
I replaced the ignition coil and all seems to be working. I just need the check engine light to go off now...thanks for the help.. a whole bunch easier than changing struts..what a nightmare that was
mettler
