SolaraGuy.com • View topic - recurring airbag warning light?
Postby minig646 » Sun Apr 10, 2011 8:16 pm
When I first bought this car, the airbag warning light was on and the dealer said he would replace the sensor. That got rid of the light, but every once in a while when someone stuffs something under the passenger seat of pushes it forwards/backwards with enthusiasm, the light comes back.
If I shut off the car, wiggle some wires under there, and restart it, it goes away for awhile. Its not a huge concern but since y'all are usually able to help I figured I'd ask.
minig646
Re: recurring airbag warning light?
Postby ThurzNite » Sun Apr 10, 2011 9:32 pm
Send me a PM tomorrow to remind me to look this up. I think there's a TSB for it. In the PM, tell me year, trim, engine, and tranny. Don't PM me tonight!!! Gotta be tomorrow so I see it tomorrow.
Dr J
ThurzNite
Postby minig646 » Sun Apr 10, 2011 9:54 pm
Will do. Thanks doc
minig646
Postby ThurzNite » Sun Apr 10, 2011 11:38 pm
Awww crap... I had some time and started looking up airbag light stuff. This's for 04-08. Maybe take a look at it, see if it helps you. I'll find something else related to 1st gens.
http://www.mediafire.com/?h8ddoab7ykwqq83
It's a pdf file
Dr J
ThurzNite
Postby ThurzNite » Sun Apr 10, 2011 11:49 pm
Ok just gonna keep uploading stuff. This's if you have side airbags
http://www.mediafire.com/?kcqq89fj0s89ic9
Dr J
ThurzNite
Postby ThurzNite » Mon Apr 11, 2011 12:01 am
Yeah I'm just upping my post count, haha.
http://www.toyotanation.com/forum/showt ... p?t=174401
That one says to reset the light, you have 3 options:
1) Unplug the battery for a while
2) Reset by jumping 2 wires
3) Use OBD2 scanner (not sure if this reads airbag lights though)
Dr J
ThurzNite
Postby minig646 » Mon Apr 11, 2011 12:13 am
Is there a prize for having a high post count? If so I want in :D
This only happens when something moves the wires under the passenger seat. Theres a ton of plugs under there, and when I wiggle all the wires it goes away. Doesn't a loose connection seem like the most likely culprit? I could just undo each plug and clean all the contacts...
minig646
Postby 02slera » Mon Apr 11, 2011 4:05 am
undo each plug and plug back in, that alone may fix it. my old explorer had power window failure one day and i took the door panel off and disconnected a plug, checked for voltage from the switch, then plugged it back in, it magically worked again and kept working for a year before i sold the vehicle. when working with the airbag system you should really use caution.
"Work must be started 90 seconds after the ignition switch is turned to the ”LOCK” position and
the negative (–) terminal cable is disconnected from the battery.
(The SRS is equipped with a back–up power source so that if work is started within 90 seconds
from disconnecting the negative (–) terminal cable of the battery, the SRS may be deployed.)"
2002 Solara SLE v6
02slera
Postby ThurzNite » Mon Apr 11, 2011 11:16 am
"The SRS may be deployed." <--- Holy crap!!!
minig646, lemme know the details of your car. There is another TSB regarding the wires under the passenger seat. It didn't specifically talk about SRS or airbags, but it regards wiring.
Dr J
ThurzNite
Postby minig646 » Mon Apr 11, 2011 12:34 pm
Sure, its a 1999 SLE V6 (1MZ-FE)
125,000 miles, everything else works perfectly. As of now there is no light, and there probably wont be unless I mess with that seat again.
Thanks
minig646
