SolaraGuy.com • View topic - Turn Signal Issues
Turn Signal Issues
Turn Signal Issues
Postby EkiMucH » Tue Apr 12, 2011 10:34 am
I am having problems with my turn signal on the driver's side. The other night I was replacing my gen1.5 tails for the gen1 and checked everything out and it was fine. Later on that night I noticed that the driver's side turn signal was blinking faster then the passenger's side. When I got home I checked it out some more and noticed that the rear was not blinking as well.
Is it because the bulb might be burnt out or maybe I damaged the wiring harness when i was replacing them on the gen1 tails? I have tried disconnecting the battery a few times and nothing happens as well and will try to replace the bulb later on today.
EkiMucH
Re: Turn Signal Issues
Postby 1gSE » Tue Apr 12, 2011 5:05 pm
[quote="EkiMucH"the bulb might be burnt out[/quote]
That's exactly why
Solara-M62 @ 5.5psi
1gSE
Postby EkiMucH » Tue Apr 12, 2011 6:15 pm
Thanks, still haven't taken care of it yet but about to
EkiMucH
