SolaraGuy.com • View topic - My Car feels like it's Brand New
Postby DSM_Lara » Mon Apr 18, 2011 8:54 pm
Had the time to change all my belts, flush all the fluids and all I can say it feels like a brand new car. Miles on it when I did the change 87865 and cant wait to drive this car till it reach 200k... (Man thats a long way.) I highly recommend doing the trans fluid. That made a big difference on my transmission. When ever the car shifts its all smooth with no lag and no jerking.
This is what I bought for preparing for a timing belt change. Of course me being me I like to get OEM parts because they last long. I would recommend getting a OEM water pump.
13568-09080 // Timing Belt
13505-20010 // Idler Sub Tensioner
13503-0A010 // Idler Sub
90311-38034 // Seal <<<<Need 2
90311-40022 // Seal
90916-03129 // Thermostat
16325-62010 // ^^^^ Gasket
16100-29085 // Water Pump
90916-02401-83 // V-Belt
90080-91088-83 // Power Steering Belt
I will also will be doing a trans, coolant and oil flush. It's your choice if you want to do these.
00272-SLLC2 // Toyota Pink Coolant <<<<< Need 2
90915-YZZD1 // OEM Oil Filter
DSM_Lara
Re: My Car feels like it's Brand New
Postby mig0s » Mon Apr 18, 2011 9:23 pm
Cool I should flush my coolant soon, when it gets hotter.
Did you do the belts yourself?
mig0s
Postby ThurzNite » Mon Apr 18, 2011 9:39 pm
Did you source the parts from the local dealership? I stumbled across this link, 1st time I seen it as a kit
http://www.piranamotorsports.com/servle ... ota/Detail
Regarding tranny fluid, are you 5sp or auto? I'm 5sp, and when I got my car it had regular tranny fluid. Cold mornings suck, couldn't shift into reverse. Drained and filled with synthetic gl-4 and it's sooo much better, but freezing mornings still not smooth till warmed up.
lol, this video rocks! http://www.youtube.com/watch?v=q0PHG88NW68
Dr J
ThurzNite
Postby ToyoSolV6 » Tue Apr 19, 2011 9:27 am
Damn dude how much did all that run you at the stealership????
Postby DSM_Lara » Wed Apr 20, 2011 11:29 am
mig0s wrote:Did you do the belts yourself?
The Timing belt was done by my uncle since I don't trust myself doing it yet. Everything else I did.
ThurzNite wrote:Did you source the parts from the local dealership? Regarding tranny fluid, are you 5sp or auto? Dr J
Everything was bought from the dealership and unfortunately I'm auto :( . But, it's ok... as I said before reliability wise this is the best car I have ever bought.
ToyoSolV6 wrote:Damn dude how much did all that run you at the stealership????
All the parts and everything came around $650. If I did that at the dealership we probably be way over 1K.... so I save a few hundred bucks. Which lead me to buy that CP-E Intake 8) Still needs to be installed....waiting for a minor part.
DSM_Lara
Postby ThurzNite » Wed Apr 20, 2011 12:02 pm
DSM_Lara wrote:All the parts and everything came around $650.
I did some more searching on the web for kits, and they all seem to come in under $300. However, they're not "Toyota" brand. They're probably OEM though. I gotta look into their warranty. Not like Toyota has a long warranty on their waterpump. 1yr unlimited miles. Meh...
Dr J
ThurzNite
Postby 02slera » Thu Apr 21, 2011 4:11 am
my car has over 160k miles now and still feels like a new car.
i have done the auto transmission fluid change and added a transmission fluid cooler which can be done for cheap and is well worth it. I also used amsoil synthetic transmission fluid. And I installed all new suspension when i lowered it and new brakes (advance auto's upgraded "lifetime warranty" rotors suck, i need to get some oem, brembo, or powerslot).
Still need to do the timing belt/water pump and seals, thanks for the part numbers.
2002 Solara SLE v6
02slera
Postby mig0s » Thu Apr 21, 2011 7:23 am
02slera wrote:my car has over 160k miles now and still feels like a new car.
Did you ever changed your timing belt?
mig0s
Postby 02slera » Fri Apr 22, 2011 8:26 pm
i bought it used at 105k miles and i should have changed the timing belt, but no i havent.
2002 Solara SLE v6
02slera
Postby JSTKVC » Sat Jul 16, 2011 12:58 pm
The local Toyota stealership tried to sell me "Transmission Fluid Exchange" and "Coolant System Exchange" both are around $149.95 each. The SA said that the tranny fluid exchange machine will swap out ALL of the fluid not partial. Is this the same as a "flush" and has anyone done this at a Toyota dealership? Also, they had "Fuel Injection and Throttle Body Service". I know what the throttle body service is but does anyone know how they clean the injectors? Is it just dumping some BG product or other additive into the tank? Anyway, I couldn't afford these services but I wantedto see if anyone else recommends it. Thanks!
2006 Solara V6 SLE Convertible - best car ever owned, enjoyed in moderation
2010 Prius - Daily Driver
2011 Lexus 450h
JSTKVC
Postby pwizzle » Sun Jul 17, 2011 8:14 pm
Here's something I did when I did my coolant drain and refill. Got this from Import Tuner a few months ago.
http://importtuner.automotive.com/12568 ... night.html
Nevermind the other articles. The top one is the only relevant article.
"To be is to do" - Plato
"To do is to be" - Sartre
"Do be do be do" - Sinatra
pwizzle
Postby KingKevin » Mon Jul 18, 2011 10:38 am
I did the transmission fluid change and it definitely feels better when shifting.
2001 SE V6
Injen intake w/ extension - Renova Grill - custom catback exhaust - 2 12" Kenwood subs - Tein s tech - neons - 8000k headlights - 3000k fogs
KingKevin
Postby JSTKVC » Mon Jul 18, 2011 12:04 pm
Thanks! I may consider the fluid exchange over standard fluid drain/refill.
I drive most stop and go and in hot weather in Palm Desert.
2011 Lexus 450h
JSTKVC
Postby ThurzNite » Thu Jul 28, 2011 12:11 am
Just curious on the coolant, you bought 2 bottles, but used about 1.25. Would you sell me your leftover coolant?
Dr J
ThurzNite
Postby DSM_Lara » Thu Jul 28, 2011 3:47 am
ThurzNite wrote:Just curious on the coolant, you bought 2 bottles, but used about 1.25. Would you sell me your leftover coolant?
Dr J
Yes for the coolant and no unfortunately I can't sale it because its on Maui.
DSM_Lara
