SolaraGuy.com • View topic - spring insulator
spring insulator
spring insulator
Postby huj2000 » Fri Apr 29, 2011 7:05 am
i recently decided to change out my struts and i cheaped out and just got the struts themselves and when i replaced them i noticed noise coming from them kinda like clunking which i decided is because i didnt change out the strut mounts, i ordered them and was about to chenge them when i noticed the lower spring insulators were pretty worn im gonna have to order those now too but what i wanted to know is there just a lower spring insulator or is there one above the spring too? thanx in advance
99 solara sle v6 - intake - headers - cat removed
huj2000
Re: spring insulator
Postby ThurzNite » Fri Apr 29, 2011 8:32 am
I dunno, but here are 2 alternatives:
In the past with other cars, I goto home depot and get clear hose that fits over the coils. It's in the fridge section, the tube that feeds the fridge freezer ice maker. They're flexible, cushiony, don't freeze or get brittle with temp or UV light.
Ann alternative is coil wire wrap from radioshack. They're used to organize electrical wires. I never went this route, but have seen others do it.
Dr J
ThurzNite
Postby 02slera » Sat Apr 30, 2011 5:39 am
Im 90% sure its only on the bottom of the spring. It has been a while since i did mine.
2002 Solara SLE v6
02slera
Postby Gregtrd » Sat Apr 30, 2011 11:02 am
^^ try again, there's one on the bottom and one on top.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby 02slera » Sun May 01, 2011 5:43 am
lol why would i try again? i said "90% sure" for a reason.
2002 Solara SLE v6
02slera
Postby 02slera » Sun May 01, 2011 5:50 am
Quickly looking into this again, here's a pic i found online, hope it helps. source MAGAUTO.com
1) Knuckle Right 2) Bolt Bolt Back 3) Lower cntrl arm Right
4) Bushing Bushing Back 5) Stopper Stopper Back 6) Ball joint Back
7) Nut Nut Back 8) Strut Right 9) Nut Nut Back
10) Coupe 2.2 liter Manual trans Back 11) Upper insulator Back 12) Lower insulator Back
13) Bumper Back 14) Upper seat Back 15) Bearing Back
16) Strut mount Right 17) Nut Nut Back
I'm not sure why the word "Back" appears so much in these part descriptions, get what you can from it.
Now that i see this pic, i think i remember the upper insulator, i think it was the strut boot, two parts in one, im not 100% sure. Gregtrd?
2002 Solara SLE v6
02slera
Postby Gregtrd » Sun May 01, 2011 12:03 pm
#11 is the strut boot and upper spring insulator
Gregtrd
Postby huj2000 » Mon May 02, 2011 8:50 am
ic, it seems like its gonna cost me more now lol :cry: thanx alot guys
huj2000
Postby huj2000 » Mon May 02, 2011 9:01 am
do you think i should replace anything else kuz so far its just the strut itself everything else i reused i already ordered all four strut mounts and will order all upper and lower spring insulators am i missing else that wouls probably have failed by now to cause the noise im getting
huj2000
Postby 02slera » Mon May 02, 2011 6:19 pm
The mounts are the problem.
if you dont already have a tool to compress the springs, count in the cost of renting or buying tools for that.
and if the boots are not torn i would not replace the upper insulators, the only reason i replaced my upper insulators on the rear was because the boots were torn and i didnt want to ruin my new struts.
2002 Solara SLE v6
02slera
