SolaraGuy.com • View topic - Bad ECM....
Bad ECM....
Bad ECM....
Postby Slut » Tue Jun 14, 2011 4:52 pm
Has anyone else encountered this... I slapped back on my supercharger over the weekend.. went around the block and car died out... Now.. I cannot communicate with many scanners... My AFC is showing the rpms jumpin to like 9000rpm when cranking(as well as the tach skipping around).. Relays are good but fuel pumps not goin on and when I jump the relay and power the pump, theres still no spark... Everything leans toward a bad computer, but I just have yet to see one go on a toyota.... Also my throttle shows no reading either on the AFC.... Any wisdom would be appreciated. Thanks guys.. Im probably gonna get an ecm from the junkyard tomorrow..
Slut
Re: Bad ECM....
Postby Slut » Thu Jun 16, 2011 5:49 pm
Nope.. ECM was good.. I was cleanin up wiring harness when I put supercharger on and I guess I ziptied a ground to snug n when I hit a big dip it ripped the main ground to the ECM.. all is good now :)
Slut
Re: Bad ECM....
Postby Gregtrd » Fri Jun 17, 2011 1:12 am
99% of the time its not the ecu, unless youre poking at it.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
