SolaraGuy.com • View topic - Stuttering
Stuttering
Stuttering
Postby 2000bluepearl » Fri Jun 17, 2011 2:58 pm
My V6 Auto has been stuttering lately. Happens when I get off the expressway (traveling 60-80 mph for a while). When I slow down to about 20 mph the rmps drop and then bounce up and down. The car also jerks around quite a bit while at a stop. If I put in neutral and rev up high and then let it go, the stuttering will stop.
I know the EGR valve needs to be replaced but I don't think thats the problem. I've had this problem off and on for 5 years but this last year has been very bad.
Any suggestions?
https://www.facebook.com/event.php?eid=176062505781761#!/profile.php?id=1348235601
2000bluepearl
Re: Stuttering
Postby Gregtrd » Fri Jun 17, 2011 4:07 pm
iac valve needs cleaning
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: Stuttering
Postby 2000bluepearl » Sat Jun 18, 2011 11:01 am
Thanks, I'll pick up some carb cleaner today and try to clean it a bit...saw vid on youtube of a guy spraying through the intake manifold down into the IAC.
2000bluepearl
Re: Stuttering
Postby Gregtrd » Sat Jun 18, 2011 1:05 pm
take the sensor off (2 Phillips screws, make sure you dont strip them)and spray it inside
Gregtrd
Re: Stuttering
Postby 2000bluepearl » Sat Jun 18, 2011 1:32 pm
Oh, ok. The guy in the vid said it would be difficult. I'll take a look for myself. Still haunt had a chance to work on it. Maybe tomorrow night iy looks like.
2000bluepearl
Re: Stuttering
Postby 2000bluepearl » Sun Jun 19, 2011 5:11 pm
Um...yeah, the screws stripped despite you warning me not to do that. I tried... the first one came loose ok...but the second one stripped.
I did spray down into the oppening of the IAC from the intake manifold. hope it helps. I'll follow up and let you know if the problem persists.
I also unscrewed part of the EGR and notised some sand in whatever little plastic thing it was...so i cleaned that too.
2000bluepearl
Re: Stuttering
Postby Toy1mzfe » Mon Jun 20, 2011 12:57 pm
^^ dont trip, thats what happedn to me. Carb cleaner didnt help my issue..
i just bought a used Tb with the sensors for replacement.
Re: Stuttering
Postby 2000bluepearl » Mon Jun 20, 2011 2:18 pm
Sorry. A used TB?
2000bluepearl
Re: Stuttering
Postby TheGreenDutch » Tue Jun 21, 2011 10:06 am
throttle body?
TheGreenDutch
