SolaraGuy.com • View topic - Brakes clunking noise
Postby Black_rainbow2003 » Sun Jul 17, 2011 3:34 am
So the other day the caliper sticks on my 99 Solara, bring to the garage and they replace caliper, pads and rotor in rear passenger side. Picked up the car and could hear a clunking noise that comes and goes after I apply and release the brakes, sounds like it's coming from the same rear pasanger side area. Return to the garage, tell them about the clunking noise and they replace bushings. Clunking noise is still there, it goes away when I apply the brakes, when brake are released, I hear the noise. Sounds like something is still sticking.
Any ideas before I return to the garage again??
Thanks
Black_rainbow2003
Re: Brakes clunking noise
Postby SleeperSolara » Sun Jul 17, 2011 9:51 am
Black_rainbow2003 wrote:So the other day the caliper sticks on my 99 Solara, bring to the garage and they replace caliper, pads and rotor in rear passenger side. Picked up the car and could hear a clunking noise that comes and goes after I apply and release the brakes, sounds like it's coming from the same rear pasanger side area. Return to the garage, tell them about the clunking noise and they replace bushings. Clunking noise is still there, it goes away when I apply the brakes, when brake are released, I hear the noise. Sounds like something is still sticking.
Thanks
Sounds like the bolts on the calipers are loose.
I've done that before....
Postby ThurzNite » Thu Jul 28, 2011 12:12 am
For discussion, I say it's the sway bar end links.
Dr J
ThurzNite
Postby sliDingSolAra... » Fri Feb 03, 2012 1:34 pm
Thanks
Do you have a TRD rear sway bar installed???? if so is it on the track setting ????
02 5spd Engine scattered, working on a 3MZ S/C set-up
sliDingSolAra...
