SolaraGuy.com • View topic - how to Inspect supercharger unit for issues
Postby rob96826 » Fri Jul 22, 2011 11:32 am
How to inspect a TRD supercharger for problems before purchasing it?....I have a chance to buy one locally...What parts are should be included in the sell as well so I don't need to track down small parts later...
rob96826
Re: how to Inspect supercharger unit for issues
Postby Akfahad » Fri Jul 22, 2011 5:40 pm
idler plate, alternator bolt and all other miscellaneous bolts should hopefully be included. Might take you a while to get everything together if not. If so happens that it doesn't, contact TRD4Life (Gabe), I'm sure he can source you some parts for whatever you are missing. Also, make sure you rotate the shroud just to make sure you don't hear any grinding noises and ask when the last time the oil was changed. Should be around every 30k miles or so.
