SolaraGuy.com • View topic - help, motor swap
help, motor swap
help, motor swap
Postby 5842solara sc » Sun Jul 31, 2011 3:31 am
If anyone can help me that would be great.
So my 2000 solara is standard. And my motor blew. So I found an automatic avalon (1995). Same 1mzfe motor. But auto trans.
So when I put the avalon motor in my car with my old trans (standard) then the motor will not spin. But whrn I loosen then trans bolts. The motor spins. It sounds like the pressure plate is hitting the fork that is connected to the pilot bearing. it seems like the clutch sticks out more or something and its hitting the trans. I took apart the trans and clutch assembly like 3 times. ugh. cant really find anything wrong.
Any ideas, thank you
2000 V6 SC'd 6lbs..
lighted crank pulley
cpe intake
255 fuel pump
supra injectors
5842solara sc
Re: help, motor swap
Postby Gregtrd » Sun Jul 31, 2011 6:35 am
Leave it to the pro ladies, when you swap out the auto drive wheel and installed your manual flywheel you forgot to take out the spacer, the auto drive wheel has 2 spacers one in the front and one behind the drive wheel. You should be able to see 9 holes on the crank if you see 8 holes then the spacer is stuck on there.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby 5842solara sc » Sun Jul 31, 2011 9:27 am
thanks for the reply.
9 holes? so there is 8 screw holes and 1 hole for the notch on the spacer?
when i pulled of the manual trans. there was only one spacer. (between the flywheel and crankshaft) and same with the auto, (only one as well). the auto trans had a skinny one and the standard had a thicker one.
so really, it should be. crankshaft, flywheel, spacer, then bolts, then clutch and flexplate?
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby Eye8Pussies » Sun Jul 31, 2011 10:21 am
crank, single spacer, flywheel, flywheel bolts, clutch (centered), flexplate, flexplate bolts
Postby 5842solara sc » Sun Jul 31, 2011 11:20 am
Eye8Pussies wrote:crank, single spacer, flywheel, flywheel bolts, clutch (centered), flexplate, flexplate bolts
Thats how I have it now. But he said I should see 9 holes?
If anything there was a smaller spacer. Could I have put the wrong one? I swore I took the big spacer from the standard trans.
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby Gregtrd » Sun Jul 31, 2011 11:39 am
I never use the spacers just make sure you use the right length bolts
Gregtrd
Postby 5842solara sc » Sun Jul 31, 2011 5:07 pm
Gregtrd wrote:I never use the spacers just make sure you use the right length bolts
i tried. lol and the bolts were to long? i could go buy shorter ones?
ill try that. i was worried the flywheel would hit the engine block or something. but ill go see if i can get shorter bolts since you said you dont use the spacers. thanks
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby Gregtrd » Sun Jul 31, 2011 7:07 pm
The auto bolts are shorter then the manual. Just use the manual bolts, no spacer and you'll be okay, when I do 5 speed swaps that's what i do.
Gregtrd
Postby Mole » Mon Aug 01, 2011 12:30 am
question answered by a pro.
Postby 5842solara sc » Mon Aug 01, 2011 12:48 am
Mole wrote:question answered by a pro.
yes, and im very glad that there is a site for our cars. :)
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby TheGreenDutch » Mon Aug 01, 2011 10:14 am
This is why SG is the best Toyota site on the net...
TheGreenDutch
Postby ozone » Mon Aug 01, 2011 9:22 pm
It's important to note that you should use new bolts on the flywheel. The bolts are torque-to-yield and should not be reused.
Good luck.
World's first V6 powered AE92. . . in progress.
ozone
Postby 5842solara sc » Sun Aug 14, 2011 2:49 am
finally got the trans on.
ugh. now worse misfire. the check engine light blinks lol.
gonna try swap on the injectors.. mayb they are faulty.
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby Gregtrd » Sun Aug 14, 2011 6:06 am
Nope try plugs! Could be an injector but plugs would be easier then I would look into the injectors.
Gregtrd
Postby 5842solara sc » Sun Aug 14, 2011 12:12 pm
I'm gonna do the plugs.. but I don't think it is it. The motor ran good in the other car.
Would the computer have to be programmed or something?
Since the motor ran good. Im thinking its my car. Or upgrades.
Supra injector or jims fuel mod. Mayb one is bad and sending to much fuel.
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
