SolaraGuy.com • View topic - factory spoiler removal 1st gen solara
Postby corlon » Wed Aug 03, 2011 11:01 pm
looking to remove the spoiler on my 99 solara to fix some rattles. i looked through the threads here, but couldn't find a solid answer. does anyone know how many 10mm bolts hold the spoiler on? i've found 2, but some threads stated a possible 4.
NiCe
corlon
Re: factory spoiler removal 1st gen solara
Postby kenny6683 » Fri Aug 05, 2011 4:11 pm
i took mine off once...i believe it was 2 plus each end had sliding tabs
once the 2 screws are removed do NOT lift up the spoiler
try pulling it towards you...spoiler will feel very stuck
i was trying to eliminate rattle as well. once removed i filled the spoiler with expanding foam
this whole process was a waste of time because i dont think it made a difference
and i ended up braking the tabs on spoiler. had to Epoxy them back on
Spoiler went back on fine but not as flush as it originaly was.
kenny6683
Postby corlon » Fri Aug 05, 2011 10:06 pm
cool thx bro.
NiCe
corlon
Postby kenny6683 » Wed Nov 16, 2011 7:00 pm
for the record...there are 4 screws. i took my spoiler off again
2 on back side and 2 under the top side of spoiler. you will see trunk has 4 holes underneath
hard to spot because the screws can be seen from different angles.
forgot to take pictures...
kenny6683
