SolaraGuy.com • View topic - squeaky!!!
squeaky!!!
squeaky!!!
Postby thenewguy » Tue Aug 23, 2011 11:03 pm
Im starting to hear loud squeaks coming from the front right quarter panel side. It squeaks whenever the car bounces /turns. It sounds as if there is break dust on your rotors and you're breaking to a stop. What's going wrong?
thenewguy
Re: squeaky!!!
Postby ThurzNite » Wed Aug 24, 2011 1:13 am
Need more info. Based on what you've provided so far:
While turning:
Check your springs, make sure they're seated properly. There are rubber isolators top and bottom of the springs that can wear through. $18 each
While driving at low speed:
Sway bar bushing. $10 each, there's 2
Does it squeak when braking?
Need more info for good diagnosis. Tell me everything.
Seeing that you're in "SoCal", I can come out and make a housecall to help diagnose. Then if you need help with the repair, I can make a 2nd trip out with proper tools.
Dr J
ThurzNite
Re: squeaky!!!
Postby thenewguy » Wed Aug 24, 2011 2:03 am
It just squeaks whenever the car is tilted in any direction.
thenewguy
Re: squeaky!!!
Postby TheGreenDutch » Wed Aug 24, 2011 12:45 pm
You might have a mouse trapped in there
TheGreenDutch
Re: squeaky!!!
Postby thenewguy » Thu Aug 25, 2011 10:45 pm
lol green. just maybe...
thenewguy
Re: squeaky!!!
Postby TheGreenDutch » Fri Sep 02, 2011 11:17 am
did your find your squeak source? lol....one time my buddy had a rats nest in his engine bay and we found a couple rat jerky peices...thats why i said that too btw...lol
TheGreenDutch
Re: squeaky!!!
Postby thenewguy » Sat Sep 03, 2011 7:26 pm
Well no but I think its the strut rubber bearings that are worn down. Do we have a front sway bar on our cars? If so, then it might be that instead
thenewguy
Re: squeaky!!!
Postby ThurzNite » Sun Sep 04, 2011 1:16 am
thenewguy wrote:Well no but I think its the strut rubber bearings that are worn down. Do we have a front sway bar on our cars? If so, then it might be that instead
Maybe you missed my post above, yes, check your sway bar bushings, as previously noted.
Dr J
ThurzNite
Re: squeaky!!!
Postby thenewguy » Sun Sep 04, 2011 7:40 pm
Yes J I looked at the previous post. thank you for narrowing down my search :]
thenewguy
