SolaraGuy.com • View topic - Remote program instructions?
Postby G_Unit » Mon Sep 08, 2003 4:09 pm
I tried to look for a post, but was not able to have any luck....I just got a remote from Ebay, and am wondering hoe can I program the remote.....
FCC: ID: GQ43VT14T I think thats the numbers on my remote, at least close enough....Thanks
G_Unit
Postby Jackass-Jeff » Mon Sep 08, 2003 8:29 pm
What year Solara, and do you have the Toyota alarm ?
1GR-FE ftw!
Jackass-Jeff
Solara Remote Programming
Postby phxjack » Mon Sep 08, 2003 9:33 pm
I E-mailed info to you. It's a rather complicated process & you may have to try it more than once before it works, but it will work.
2001 Solara SLE Convertible...Red
TRD Supercharger
TRD Strut Tower Brace
TRD Stage 3 Suspension Package (7-piece body kit, 17" wheels, Toyo Proxes T1-S tires, lowering springs, and struts)
TRD Sport Muffler
TRD Performance Air Filter
phxjack
Postby Jackass-Jeff » Mon Sep 08, 2003 9:51 pm
It's almost different every year... hopefully you gave him the right one :D
1GR-FE ftw!
Jackass-Jeff
Postby G_Unit » Tue Sep 09, 2003 5:15 pm
Sorry about that its a 2000 v6sle...thanks....Amit
G_Unit
Postby Guest » Wed Jan 21, 2004 11:34 am
Hi,
I would also appreciate it if anyone can email me programming instructions for a 99 Solara. phxjack I see you emailed Gunit, can you email me too, anbody pls help?!
My email is chap98@hotmail.com
Many thanks.
Guest
remote instructions
Postby jetfixer01 » Wed Jan 21, 2004 3:35 pm
emailed the 99 info to you.
jetfixer01
Postby Guest » Wed Jan 21, 2004 3:42 pm
Hi jetfixer,
I'm sorry, but which email address? I can't seem to find it anywhere?
Did you use chap98@hotmail.com?
Thanks
Guest
Re: Solara Remote Programming
Postby offthahook » Thu Jan 22, 2004 5:13 am
phxjack wrote:I E-mailed info to you. It's a rather complicated process & you may have to try it more than once before it works, but it will work.
Me too! Ebay dealio. 99 Solara SLE V6. 2 button and panic on the back. THANKS!!!! Can this be a FAQ or is that too dangerous?
jggoode@yahoo.com is the key.
offthahook
Postby Cast » Thu Mar 04, 2004 6:07 pm
Well I wanted to reply to this post and give the instructions that worked for my 2000 SLE for those of us too paranoid to hand out email addresses. :lol:
2000 - 2002 Camry
1. Start with the following conditions:
a. Key Is out of the ignition.
b. Driver door is open (all other doors are closed).
c. Driver door is unlocked (other door locks don't matter).
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock. A
lock/unlock cycle consists of pressing the power lock switch, followed by pressing the power unlock switch on the driver's door panel. Use an even pace and try to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Using the power lock/unlock switch on the driver's door, perform 5 lock/unlock cycles starting with lock (just as
you did previously).
b. Turn the ignition to ON (as far as you can go without cranking your engine), then back to OFF.
c. Turn the ignition to ON (as far as you can go without cranking your engine), then back to OFF.
d. Remove the key from the Ignition.
5. Within 3 seconds, the power door locks should cycle (lock then unlock) automatically Indicating successful entry into
programming mode. Return to Step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle (lock then unlock) once indicating successful programming. If the
door locks don't cycle, or cycle twice, repeat steps 6a and 6b - this remote has not been accepted.
c. Repeat steps 6a and 6b for each transmitter that will operate the vehicle, including any old transmitters.
7. Close driver door.
Instructions courtesy of some guy that posted them somewhere I googled up.
BTW my dealership wanted almost $150 for a replacement remote. I bought one for $1.99 on ebay. It works great!
:lol: :lol: :lol:
Cast
