SolaraGuy.com • View topic - cv joint
cv joint
cv joint
Postby huj2000 » Thu Sep 08, 2011 11:20 am
i think my cv joints might be bad but i wanna make sure before i order new ones if im right any tips on how i would check mine to see if they are bad, the reason i think they might be is becasuse i changed out my strut mounts and i think i might have over extened the cv joint because i didnt have the hub sitting good and for a little while it was leaning out pretty good and when i drive i hear a very sublte almost grinding sound it is very faint but if its just starting to get bad id rather just replace them now
99 solara sle v6 - intake - headers - cat removed
huj2000
Re: cv joint
Postby ftw » Thu Sep 08, 2011 1:01 pm
Bad CV joints usually make a clicking sound especially when reversing.
New Daily: 2005 Corolla XRS
SOLD: DWP 1999 SE V6| Eibach/Tokico| Super Pro Dogbone Bushings, FSB Bushings| Energy Suspension Front Control Arm Bushings| Injen Intake
ftw
Re: cv joint
Postby chriscarter » Thu Sep 08, 2011 2:52 pm
Agreed - worn CV joints make a clicking when turning hard one way or the other. Your subtle grinding may be from a bent hub backing plate that may have been pushed when the suspension was apart. Also check your front pad wear indicators and slides.
PS - Easiest way to fix a bad CV joint is to buy a reman or new complete axle. Many online sources with reasonable prices. I recently found brand new ones for an older Celica for about $75 each - entire axle.
chriscarter
Re: cv joint
Postby SleeperSolara » Fri Sep 09, 2011 9:04 pm
If you have pulled the CV joint out too far you can re-seat it and it should be fine.
Re: cv joint
Postby chriscarter » Sat Sep 10, 2011 7:08 am
If it was stuck too far out, it never would have fit back into the hub splines and tightened down properly. I guess we're assuming that it did since the car is now driving.
chriscarter
Re: cv joint
Postby SleeperSolara » Sun Sep 11, 2011 5:08 pm
Well i've popped out my new CV joints when i was workin' on them before and just re-aligned them and they popped right back in place.
