SolaraGuy.com • View topic - Ben's fail mod
Ben's fail mod
Ben's fail mod
Postby TRD_Sloara » Sat Sep 10, 2011 1:41 pm
So it's Saturday afternoon, and I don't have much to do, so I decide to tackle the Jim's fuel line mod, and possibly walbro fuel pump if things go well. I go to take the fuel line into the bottom of the filter off, and the c*cksucker stripped on me. I even doused it in WD40 before going at it, but it was pretty rusted, as it looks like it has never been changed. :evil: Has anybody else run into this issue? What could I do to fix this issue? :bad-words:
TRD_Sloara
Re: Ben's fail mod
Postby chriscarter » Sat Sep 10, 2011 5:01 pm
If you're referring to the flats on the flare nut rounding off, use a small set of Vise-Grips (locking pliers). Be careful not to indent the flats too much with the jaws of the pliers. Chances are, you can use a wrench to tighten it because it will only have rounded turning counter-clockwise (when viewed from the bottom). Go buy yourself a 14mm (verify that on your car) flare nut wrench which is about 3/4 of a box wrench. Don't try to loosen a flare nut with just an open-end wrench. You will round it off sooner or later.
chriscarter
Re: Ben's fail mod
Postby TRD_Sloara » Sat Sep 10, 2011 6:08 pm
Thank you. It is in fact 14mm (opposed to the 12mm mentioned in the archived tutorial). Will try this again tomorrow if I have time.
TRD_Sloara
