SolaraGuy.com • View topic - 1MZ ECU and harness
1MZ ECU and harness
1MZ ECU and harness
Postby Smaay » Fri Oct 07, 2011 8:34 am
Im so sorry for the newb question. i need to know if the 00-02 camry has the same ECU and harness as the Solara. Thanks for your responses
1990 Celica All-Trac 3S-GTE
1997 Celica GT 1MZ/3MZ hybrid
1997 Supra 2JZ-GTE
2001 Celica GT-S 2ZZ-GTE
1998 Dodge Ram Cummins Turbo Diesel
Thats alot of BOOST!!!!
Smaay
Re: 1MZ ECU and harness
Postby S.Z.-Alpha » Fri Oct 07, 2011 2:56 pm
Yes, but it's programmed different. You see, from the old Camry with the same V6's have slightly lesser HP compared the 1MZ's of Solara.
2000 Toyota Solara a.k.a "Goldie" SLE V6 //PARTS: TRD Muffler w/ Stock pipes, K&N filter, Tokico Blue Shocks w/ Stock Springs, Kenwood H/U with x4 JVC speakers(250x2 Front and 290x2 Rear) w/ JL 1000 watt amp.
S.Z.-Alpha
Postby Smaay » Mon Oct 10, 2011 8:00 am
Thanks for the response, so in theory i could still use a solara ECU? the pinouts are the same?
1997 Supra 2JZ-GTE
Smaay
