SolaraGuy.com • View topic - Help... dunno what's wrong with my clutch
Postby mig0s » Fri Nov 04, 2011 2:55 pm
Hey y'all,
So a month ago my clutch pedal dropped to the floor and wouldn't get up. Found out my reservoir is empty so I changed my master cylinder and slave cylinder. Bled the clutch and everything went back to normal... for a month or so. A few days ago, my clutch's friction point went really low. When I press the pedal half way through, it does nothing and has no pressure. It became really hard to shift, especially when I try to engage the first gear. Now I bled the clutch again and the friction point is still low and there's no pressure when I press the clutch for 1/3 of the travel distance. My master and slave cylinders are NEW. Anybody can help me?
mig0s
Re: Help... dunno what's wrong with my clutch
Postby ACProductions » Fri Nov 04, 2011 4:00 pm
This is a stupid question but it helps with diag.
Did you set the clutch engagement height correctly?
This is done by loosening the 12 mm nut on the Master cylinder shaft, where it connects to the pedal, before the cotter pin and clip. You then set the travel and engagement point by turning the shaft either clockwise or counter clockwise.
This once happened to me and I found out that I had forgotten to tighten said 12mm nut on the MC shaft and it had spun itself all the way down to the point that I could only halfway disengage my clutch
FREE CHILTON MANUAL
The speed at which a woman says "nothing" when you ask her what's wrong is inversely proportional to the size of the coming storm.
ACProductions
Postby mig0s » Fri Nov 04, 2011 8:27 pm
^^ I'm gonna go check tomorrow. Thanks for the reply. Hope that nut is not too hard to access.
mig0s
Postby ACProductions » Fri Nov 04, 2011 9:02 pm
It's a bit of a b****. I always have to recline the seat all the way back, and go head first down into the pedals and get 1 molecule away from dislocating my shoulder. Soooooo yeah
FREE CHILTON MANUAL
ACProductions
