SolaraGuy.com • View topic - tranny stuck in gear. bad tranny?
Postby freshdenamufcka » Thu Nov 24, 2011 11:21 am
i cant get my tranny out of gear. it will shift but the car wont move. if i leave it in neutral and release the clutch pedal a little bit the car would drive. not sure what happend this morning because it was fine last night.
anyone ever have this problem and know what it might be? i just got my clutch done few months ago so i dont really wanna have to replace the whole tranny. if worst comes to worst...are there any other trannys would fit the gen 1 solara that are better?
freshdenamufcka
Re: tranny stuck in gear. bad tranny?
Postby Gregtrd » Thu Nov 24, 2011 3:39 pm
What kind of clutch did you get installed?
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Gregtrd » Thu Nov 24, 2011 4:02 pm
Did you break in the clutch properly?
Gregtrd
Postby freshdenamufcka » Fri Nov 25, 2011 5:03 am
my clutch is a exedy stage 1. i dont drive my car hard at all. its been 5k since i got it replaced.
it won't shift into any gear except reverse. but the car won't move. it only moves if i leave it in neutral and slowly release the clutch.
is there anything i can look at to see if its broken? i popped plastic off where the shifter is and removed the boot cover. the shifting mechanism seems to be intact and nothing broken.
thanks!
freshdenamufcka
Postby Gregtrd » Fri Nov 25, 2011 10:53 am
Does it make any grinding noise when you release the clutch.
Gregtrd
Postby freshdenamufcka » Fri Nov 25, 2011 4:59 pm
not really grinding but, just makes that about-to-stall sound. and it does stall if i release the clutch all the way. its def stuck in gear, just not sure which one.
freshdenamufcka
Users browsing this forum: Google [Bot] and 17 guests
