SolaraGuy.com • View topic - How to check gear oil level?
Postby freshdenamufcka » Sun Nov 27, 2011 2:38 pm
i searched and couldnt find any info on this even in the manual. is there a dipstick i can pull out to check the level?
freshdenamufcka
Re: How to check gear oil level?
Postby 1gSE » Sun Nov 27, 2011 2:45 pm
fill it till it pours out....re-install the plug. You should be able to feel oil at the bottom of the hole
Solara-M62 @ 5.5psi
1gSE
Postby freshdenamufcka » Sun Nov 27, 2011 3:27 pm
not sure what you're talking about. so you mean remove the size 24 bolt and fill it to the top and put the bolt back on? what bottom of the hole are you referring to?
freshdenamufcka
Postby 1gSE » Sun Nov 27, 2011 4:36 pm
the top one where you fill it (at the front of the transmission) Once it starts pouring out, you're good. If you stick a finger in it and its even with or close to the lower part of the hole, you're good. Guess I could have cleared that up a bit
Solara-M62 @ 5.5psi
1gSE
Postby freshdenamufcka » Sun Nov 27, 2011 8:47 pm
sorry bro im still confused. this is for a manual transmission right? i have to remove a size 24 bolt in order to fill the gear oil. i guess pictures would help lol. ill post one tomorrow
freshdenamufcka
Postby 1gSE » Mon Nov 28, 2011 1:55 am
Solara-M62 @ 5.5psi
1gSE
