SolaraGuy.com • View topic - Fuel Efficiency: Use A/C or have windows down?
Postby krzyray » Sat Sep 13, 2003 10:56 pm
When driving on the freeway (80mph), is it more fuel efficient to use air condition or does having both windows all the way down cause too much drag and end up making the car work harder thus use more gas?
krzyray
re:
Postby crusin by » Sun Sep 14, 2003 4:27 am
I've heard on the radio a while ago that its better to drive with the a/c on and the widows up. Will your alternator still use the juice if your a/c is not on? If so, I say blast the a/c all day.
Richard
97CamryXLEV6
crusin by
Postby Guest » Sun Sep 14, 2003 4:58 pm
maybe you could get some government funding and do a test for us
and just for fun find out what happens with the air on and the windows open
shoe
Guest
Postby krzyray » Sun Sep 14, 2003 5:11 pm
Anonymous wrote:maybe you could get some government funding and do a test for us
shoe
Think you're misinterpreting the question. I am trying to find out what uses less gas on the freeway driving at 80mph. Either using your A/C with windows UP. Or using no A/C and having both of your windows all the way down.
krzyray
Postby onefiend » Sun Sep 14, 2003 5:45 pm
shoe
Some people just dont understand the meaning of "sarcasm" LOL
onefiend
Postby austinsolara » Sun Sep 14, 2003 6:27 pm
I heard somewhere recently that 40MPH is the tradeoff between windows down and A/C.
-02 SE Conv
austinsolara
Postby fotodad » Sun Sep 14, 2003 8:30 pm
shoe
...or have a use for it in within this forum.
I think it's a legitimate question; one which I've often asked, as well.
2004 Solara SLE
Lunar Mist/Graphite
InvisaGuard
20% tinting all around
Michelin Pilot A/S
fotodad
Postby krzyray » Sun Sep 14, 2003 9:17 pm
austinsolara wrote:I heard somewhere recently that 40MPH is the tradeoff between windows down and A/C.
Yup you are right! :) I just finished a search in Google, and found this: http://www.reconnectingiowans.org/train ... ation2.htm
Use air-conditioning during higher-speed driving only (over 40 mph).
"Air conditioning can be your car's biggest summer energy use. However, at high speeds, air-conditioning actually wastes less energy than rolling down your windows; this is because a “smooth” car uses less energy to run the air conditioner than would be lost due to "drag" at higher speeds. Rather than running the air conditioner continuously, use the vent setting as much as possible. When you get to your destination, park in the shade to reduce the need for using the air conditioner."
krzyray
Postby Fletch » Mon Sep 15, 2003 3:26 am
I got bored coming back from a 4 hour trip once...
I accelerated to 120 mph going uphill with the A/C on, windows closed much easier than I could on level ground, A/C off windows open. With windows open it just seemed to take forever to get from 110 to 120 mph.
2006 Legacy GT spec.B
Fletch
Postby Guest » Mon Sep 15, 2003 12:51 pm
sarcasum nothing if you really want to know fill up a tank at 2 am go out on the freeway windows closed no AC drive from 1 end of town to the other at what ever speed. for x amount of miles or kilometers.
THEN FILL UP YOUR TANK AGAIN
write down how much it cost when the depth stop kicked in
get back in your car and do the same run with your windows open at the same speed go back to the gas station fill up again and wrtie down the cost when the pump stops automatically ( depth stop)
now do the run 1 more time with your ac on and your windows up.
see the patern? if you really want to know find out for ur self? shouldnt take more than an hour
and like i said if you really want to have fun with this do the test with both the ac on the open window drag
shoe
Guest
