SolaraGuy.com • View topic - 99 solara se v6 manual with no reverse lights
Postby corlon » Tue Jan 24, 2012 10:51 pm
noticed that my reverse lights no longer are coming on when i shift into reverse. checked everything on the electrical side of things and that looks good. i have power to the red/ blue wire @ the transmission and nothing on the red /blk reverse wire @ the transmission. i can jump across these 2 wires and then the reverse lights come on. wondering if there is an adjustment for the manual transmission cable or possibily the switch is bad. hoping someone else has had this issue and knows the fix. thanks.
NiCe
corlon
Re: 99 solara se v6 manual with no reverse lights
Postby 1gSE » Wed Jan 25, 2012 12:12 am
replace the back up light switch on top of the transmission. I can't remember what size socket you need
Solara-M62 @ 5.5psi
1gSE
Postby alltrac92 » Wed Jan 25, 2012 10:40 pm
I had the same problem it was the switch.
http://www.amazon.com/Standard-Motor-Pr ... 79&sr=1-10
alltrac92
Postby corlon » Wed Jan 25, 2012 11:35 pm
cool. ordered one today. let ya know if its a fix. thanks again.
NiCe
corlon
Postby corlon » Sat Jan 28, 2012 11:32 pm
its a fix. thanks for the info guys!!!
NiCe
corlon
Postby corlon » Mon Feb 13, 2012 10:29 pm
small issue with this new sensor. sometimes in 1st and 2nd gear when i'm about to shift into the next gear (top of the rpms, not shifted yet) the reverse lights will come on. seems to do it more so when the car is cold. does something need to be adjusted?
NiCe
corlon
Postby alltrac92 » Fri Feb 24, 2012 7:13 pm
Did you use a new crush washer with the new sensor?
alltrac92
Postby corlon » Fri Feb 24, 2012 11:26 pm
hi, i don't believe so. i'll pull it off and check. thanks.
NiCe
corlon
Postby alltrac92 » Sat Mar 03, 2012 9:07 pm
It uses the same crush washer that is on the transmission drain and fill plugs 90430-18008
alltrac92
