SolaraGuy.com • View topic - sicking brakes
sicking brakes
sicking brakes
Postby vncntsbr » Mon Feb 27, 2012 10:45 pm
hello everyone,
I am new to this forum and i hope that someone can help me.I am driving a 99 toyota solara 3.0L Engine front and rear disc brakes. I recently had to replace the master cylinder and the brake booster
because the brake fluid was leaking into the brake booster. the problem I am having now is that all 4 disc brake calipers, after driving for about 2min stick and the calipers will only retract if I let the car sit for a while or when I open the bleed screw then all 4 calipers will retract immediately and the car will drive but for only 2 min and the brakes will lock again. It is as if the brake fluid pressure is building up but not being released when I take my foot off the brake. does anyone have any suggestion on what I need to check?
vncntsbr
Re: sicking brakes
Postby Gregtrd » Mon Feb 27, 2012 11:42 pm
You need to adjust your brake booster, the adjustment is done on the pin that pushes on the master cylinder, been there done that, trust.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: sicking brakes
Postby vncntsbr » Wed Feb 29, 2012 12:47 pm
thanks i will try that as soon possible
vncntsbr
Re: sicking brakes
Postby vncntsbr » Fri Mar 02, 2012 6:44 am
thanks gregtrd Iadjusted the pushrod on the booster and everything is good
vncntsbr
Re: sicking brakes
Postby TheGreenDutch » Fri Mar 02, 2012 1:14 pm
Another reason why SG is the best. Results!
TheGreenDutch
