SolaraGuy.com • View topic - o2 sensor CEL code repair/part help
Postby pro956 » Tue Apr 03, 2012 8:12 am
My CEL came on so I stopped by AZ and go this info:
h02s11 heater condition (heated oxygen sensor bank 1 sensor 1)
the powertrain control module monitors the oxygen sensor heater. The computer has recognized a failure in this circuit.
Probably causes:
Oxygen sensory defective, poor connection at oxygen sensor, or check circuit-fuse.
I assume I need to change my O2 sensor, can someone tell me the part number? I tried to search the CEL code h02s11, but I can't find any info on it here. Everything here is in Pxxxx...
Can someone point me towards the correct part?
Also, could someone describe/send a pic of where the fault sensor is?
Thanks!
AIM: pro956
2002 5-speed se v6
pro956
Re: o2 sensor CEL code repair/part help
Postby 1gSE » Tue Apr 03, 2012 10:02 am
Thats because h02s11 isn't a code, thats telling you what sensor it is. Its the one in the rear manifold.
http://www.rockauto.com/catalog/x,carco ... ttype,5132
Solara-M62 @ 5.5psi
1gSE
Postby pro956 » Tue Apr 03, 2012 11:17 am
oh ok. thanks. can someone take a photo of their engine and point out where the sensor is that i'm trying to replace?
i can clearly see heated oxygen sensor (bank 1 sensor 2) but i'm having trouble finding heated oxygen sensor bank 1 sensor 1...
thanks!
AIM: pro956
2002 5-speed se v6
pro956
Postby pro956 » Tue Apr 03, 2012 11:28 am
here are some pics, can someone use paint or whatever to show me where the sensor is?
http://www.mediafire.com/imageview.php? ... 0s&thumb=6
http://www.mediafire.com/imageview.php? ... da&thumb=6
http://www.mediafire.com/imageview.php? ... ri&thumb=6
thanks again.
also is Denso 234-4137 the part I need if I want to go with Denso?
AIM: pro956
2002 5-speed se v6
pro956
Postby 1gSE » Tue Apr 03, 2012 3:48 pm
You'll have to get under the car to see it. There's no way to get to it from the top. And that's the sensor after the cat. You want 2344622
Solara-M62 @ 5.5psi
1gSE
Postby pro956 » Wed Apr 04, 2012 11:26 am
Well I got under my car and found the sensor, but it was hard as hell to reach. Knowing where it was underneath made it easy to find from the top and I think I will replace it from the top now as it appears to be more accessible that way.
I believe it is right there in the middle:
http://www.mediafire.com/imageview.php? ... ks&thumb=6
I ordered the new sensor and a 22mm. I'll let you know how it goes. If anyone Marylanders want to help out, let me know!
http://www.amazon.com/gp/product/B000C5 ... 00_details
http://www.amazon.com/gp/product/B000NP ... 00_details
AIM: pro956
2002 5-speed se v6
pro956
Postby 1gSE » Wed Apr 04, 2012 12:07 pm
I honestly think you'll be better off going from under, just put the car in jacks, its not a hard job.. The wrench may work, but you have a better chance of rounding it off vs an O2 sensor wrench. Be sure to hit it some breakfree or pb blaster
Solara-M62 @ 5.5psi
1gSE
