SolaraGuy.com • View topic - ABS light after installing coilovers?
Postby mig0s » Sat May 19, 2012 5:07 pm
So right after I've put on the suspension the ABS light came on my dashboard. Sensors seem to be ok, what might be the reason?
mig0s
Re: ABS light after installing coilovers?
Postby 1gSE » Sat May 19, 2012 7:01 pm
rear sensor? IIRC, letting the rear drop too much will damage the wires. Common problem when doing suspension work
Solara-M62 @ 5.5psi
1gSE
Postby mig0s » Sat May 19, 2012 8:52 pm
Rear is not even that dropped... How can I know which sensor is screwed? Is it ok if I leave it like that?
mig0s
Postby 1gSE » Sat May 19, 2012 9:12 pm
No, I meant during the installation.
You can drive like that, but during a panic stop, the rears might lock. Your ABS is disabled now
Solara-M62 @ 5.5psi
1gSE
Postby thenewguy » Sat May 19, 2012 9:51 pm
yup you must of pulled a wire from one of the sensors that are on the caliper from letting one of the independent rears too low during installation. i'd double check the rear for loose wiring by the sensor
thenewguy
Users browsing this forum: Google [Bot] and 16 guests
