SolaraGuy.com • View topic - Rewiring a sensor wire at the connector on PCM
Postby needmorecrap » Mon Jun 11, 2012 5:44 pm
Hard to explain and harder to search for. Let's not say how this happened, but I now have a wire coming out of the connector on the ECM for the knock sensor that is only about 1" long. What are my options here to get it long enough to work with again? I'm sure i can solder a wire onto the end, but is there a way to get a new longer wire fed directly into the connector?
needmorecrap
Re: Rewiring a sensor wire at the connector on PCM
Postby 1gSE » Mon Jun 11, 2012 6:21 pm
The only other thing I can think of would be pulling the connecter out of the harness, removing the old wire and soldering a new one in place
Solara-M62 @ 5.5psi
1gSE
Postby corlon » Mon Jun 11, 2012 8:56 pm
you could also pull the pin or similar pin out of a junkyard solara / camry and cut that wire back far enough so you have room to work with it.
NiCe
corlon
