SolaraGuy.com • View topic - Running rich and sputtering at idle
Postby jgood738 » Wed Jun 27, 2012 9:38 am
Dash lit up on my 2000 SLE and I had misfire and o2 sensor codes coming up. I changed the o2 sensor and spark plugs. Car ran great for 140m. Now it's sputtering at idle and running super rich. Could the o2 sensor I bought be bad?
jgood738
Re: Running rich and sputtering at idle
Postby TheGreenDutch » Wed Jun 27, 2012 11:09 am
was it the one near the firewall? Were did you purchase the sensor from?
TheGreenDutch
Postby jgood738 » Wed Jun 27, 2012 11:28 am
Yes. Its a denso. Got it a while back at advance.
jgood738
Postby 1gSE » Wed Jun 27, 2012 1:25 pm
Are you getting any codes now?
Solara-M62 @ 5.5psi
1gSE
Postby jgood738 » Wed Jun 27, 2012 4:02 pm
It was the one by the firewall. A denso from ridge. I havent pulled the codes yet. Ill will tomarrow.
jgood738
Postby navarachi » Thu Aug 06, 2015 9:46 pm
we had sputtering at idle and it was EGR valve. They can just clean it for almost next to nothing and it should fix the issue.
navarachi
