SolaraGuy.com • View topic - Removing Spoilers
Removing Spoilers
Removing Spoilers
Postby jello » Fri Sep 19, 2003 2:36 pm
How do you remove the spoiler on a 2000 Solara? I need to take it off and put some washers under it or something. I used dynamatt extreme 3 layers and the stupid spoiler still rattles like crazy when My bass hits... I guess 1700 watts can do that to a guy.
00 solara sle
jello
Postby WTF?? » Fri Sep 19, 2003 3:15 pm
Im sure if you remove the panels from underneath the trunk, youll see how to get to it
Retired... its been fun Image
WTF??
Postby Guest » Fri Sep 19, 2003 4:36 pm
Yeah thats what I did I tightened down the spoiler like non other but yet It still rattles like crazy. Anyone else have this problem? How did you fix it?
Guest
Postby onefiend » Fri Sep 19, 2003 5:17 pm
There's a roll of paper insulation you can buy for the trunk. My friend has this material on his Accord Coupe. You stick this material that looks like paper and foil on the backside of the trunk and it keeps it from rattling.
onefiend
Postby Guest » Sat Sep 20, 2003 12:47 pm
I have 4 layers of dynamat extreme............ the trunk moves a good half an inch up and down when the bass hits.
Guest
Postby jello » Sat Sep 20, 2003 12:48 pm
that was me
00 solara sle
jello
Re: Removing Spoilers
Postby TrevDog » Mon Sep 22, 2003 1:04 pm
jello wrote:I guess 1700 watts can do that to a guy.
Wow, 1700watts, that must be crazy loud. I hope the spoiler removal works!
2000 Silver Solara SLE V6 Auto
Street Glow Blue Line green undercar neon lighting
Street Glow blue neon tubes under seats and red neons in trunk
400watt JBL amp and 10in sub in the trunk
TrevDog
Postby Peter » Mon Sep 22, 2003 4:10 pm
i stuck rammat between spoiler and trunk, got rid of the rattle in the spoiler, now there's more rattle from somewhere inside the trunk.... i give up, i dont hear the rattle from inside, so im fine.
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby krook » Tue Sep 23, 2003 11:02 am
just remove the carpet from the inside trunk lid. pop off those plastice holders with a panel remover and once removed, you'll see the bare metal part of the inside of the trunk lid. remove bolts, and disconnect wires if need to.
krook
spoilers
Postby Burning solara » Sat Sep 27, 2003 2:51 pm
HEH I accidently covered up my screws to my wing with raam mat. Where are the locations of the screws?
Burning solara
Re: spoilers
Postby krook » Tue Sep 30, 2003 11:19 am
Burning solara wrote:HEH I accidently covered up my screws to my wing with raam mat. Where are the locations of the screws?
duuuuude!.... why don't you remove the ram mat? if that's not possible, try and poke around to see if you can locate the hole the screw goes into. good luck!
krook
