SolaraGuy.com • View topic - CEL came and went away
Postby KingKevin » Fri Aug 17, 2012 6:53 pm
So I was just driving my car back from work as per usual and sometime during the commute I noticed the check engine light came on. I was kinda bummed out but its a busy week and since I dont own a scanner myself I figured I would stop by autozone whenever I got the chance. Three days later and its gone when I start up the car. So my question is: Is it fine? Should I still go scan it and see what was up?
Should also mention that the light is on on one of the key turns so its not a burnt bulb.
2001 SE V6
Injen intake w/ extension - Renova Grill - custom catback exhaust - 2 12" Kenwood subs - Tein s tech - neons - 8000k headlights - 3000k fogs
KingKevin
Re: CEL came and went away
Postby 1gSE » Fri Aug 17, 2012 7:40 pm
It should be ok. After a few key cycles, if the ecu doesn't detect a problem, it'll turn the CEL off. I wouldn't worry about it
Solara-M62 @ 5.5psi
1gSE
Postby KingKevin » Sat Aug 18, 2012 6:48 pm
Alright thanks! And I knew for sure you would be the first to respond to my post... you always are haha thank you
2001 SE V6
KingKevin
