SolaraGuy.com • View topic - Oodles of codes...
Oodles of codes...
Oodles of codes...
Postby minig646 » Sat Sep 08, 2012 3:32 pm
Hey guys, I recently had a decent sized exhaust leak fixed on my '99 SLEV6's flex pipe. It was causing me to get code P1135. The leak sounds fixed and the car runs great, but the light came back on after a few miles. This time I get 3 additional codes: P1130, P1133, and P0125.
This screams rear O2 sensor to me, but what are the odds of two unrelated problems- the leak and the sensor failure- happening at the same time? Can a leak cause a sensor to fail?
minig646
Re: Oodles of codes...
Postby GzNutz » Sat Sep 08, 2012 6:56 pm
Is the wiring to the sensor damaged?
Postby minig646 » Sat Sep 08, 2012 7:31 pm
No, I don't think so. I checked all the voltages for the sensors and they all seem to be in range. Correct me if I'm wrong:
minig646
Postby 1BADGTS » Sat Oct 06, 2012 6:10 pm
Just sent you info about this to your other post !! If this is a California Spec car there is a TSB from Toyota that would fix it pretty easily with no parts !! There is a potential wiring connection issue at the A/F Heater Relay that would cause all these codes. I have the TSB if you need it.
****THE FLEET****
2001 Toyota Highlander Limited V6 - "The Wifes"
1999 Toyota Solara SE V6 5 Speed - Family Pimp Ride
1993 Toyota Celica GT-Four R/C Clone - Weekend Fun
1987 Toyota Supra Turbo 5 Speed Sport Roof - Just Because !!
1BADGTS
