*Help Please* Power Steering fluid leak!
Hey so I'm having an issue with my power steering fluid leaking. I have identified that it is leaking about 6-10 inches below the hood (towards the ground) from a hose which is directly to the left of the radiator behind and below the passenger headlight. I've all but 100% concluded that this hose is the Pressure Hose, however I've been informed that there are 2 factors that determine what exact part will work. A. I'm being told there are two different sizes. One being 47 1/2 and the other being 43 1/4. B. I'm being told that in addition to the size, the correct Pressure Hose is also determined by whether I have a "switch port" or not. Now this "switch port" they are talking about I assume is determined by whether or not I have Air Conditioning (which I do) I have a 99' SE V6. If anyone knows what exact part I'm describing and what the correct size would be, that would be great!!!!!!!! I'm looking for feedback asap as i go through a quart of fluid a week now!
Nemesis85 - Regular SolaraGuy Member
