SolaraGuy.com • View topic - Stock radio won't turn on?
Postby Brandoe91 » Tue Oct 23, 2012 5:54 pm
The stock radio in one of my Solara's is not turning on. I have checked both radio 1 and radio 2 fuses and none are blown. I also plugged the radio in my other solara and it worked fine. Any idea on what to check next?
TRD S/C 6psi - OBX Full Exhaust - Injen intake ( 226whp untuned).
New Setup - 3mzfe - obx full exhaust - aem fic - innovate mtx-l wideband - Cpe intake. (Estimated 220whp) dyno numbers coming soon.
Brandoe91
Re: Stock radio won't turn on?
Postby SolaraPete » Tue Oct 23, 2012 7:23 pm
Using a digital multimeter, verify that you have 12v on the blue/yellow wire (constant power) and gray wire (switched power - make sure your key is on) behind the radio. If either of those arent showing 12v then you missed a blown fuse somewhere. It may not be labeled as a "radio" fuse, so be sure to check all the fuses inside and under the hood.
SolaraPete
Postby Brandoe91 » Tue Oct 23, 2012 7:45 pm
SolaraPete wrote:Using a digital multimeter, verify that you have 12v on the blue/yellow wire (constant power) and gray wire (switched power - make sure your key is on) behind the radio. If either of those arent showing 12v then you missed a blown fuse somewhere. It may not be labeled as a "radio" fuse, so be sure to check all the fuses inside and under the hood.
Thanks,just the info I was looking for. I will let you know how it goes.
Brandoe91
Postby sliDingSolAra... » Wed Oct 24, 2012 11:27 pm
use a hammer and forcefully tap it until it turns on, that always works for me :boss:
02 5spd Engine scattered, working on a 3MZ S/C set-up
sliDingSolAra...
