SolaraGuy.com • View topic - Intermittent ABS light and brakes locking up.
Postby TheGreenDutch » Sun Oct 28, 2012 9:10 am
hey I just got some new tires up front recently. They are 225/60/16 and my rears are 205/50/16. A couple days later my ABS light came on and off. Now every once an a while under a hard brake situation the wheels lock up and I can't stop my car unless I pump and slam the brakes when the ABS kicks in. Could my offset be messing with my ABS sensors throwing it out of wack? When the abs kicks in my car will not stop unless I use emergency and pump the brake. yikes!!!
TheGreenDutch
Re: Intermittent ABS light and brakes locking up.
Postby 1gSE » Sun Oct 28, 2012 9:16 am
I'd say tire size definitely has something to do with it. That's a 1.5in difference in diameter.
Solara-M62 @ 5.5psi
1gSE
Postby 1BADGTS » Sun Nov 04, 2012 6:46 pm
Tires most likely !! The ABS system is seeing different speeds from the front and rear. It also is seeing that one end stops faster than the other !! You need to run 4 properly sized tires on the car and see what it does. I will bet it will drive much better !!
****THE FLEET****
2001 Toyota Highlander Limited V6 - "The Wifes"
1999 Toyota Solara SE V6 5 Speed - Family Pimp Ride
1993 Toyota Celica GT-Four R/C Clone - Weekend Fun
1987 Toyota Supra Turbo 5 Speed Sport Roof - Just Because !!
1BADGTS
Postby TheGreenDutch » Fri Nov 09, 2012 8:05 am
I disabled the ABS :) I hated that $hit anyway
TheGreenDutch
Postby minig646 » Mon Nov 12, 2012 8:27 am
You disabled your ABS just in time for winter. I like your style. I think I'll keep mine though.
minig646
Postby TheGreenDutch » Mon Nov 12, 2012 8:44 pm
drove a 91 accord for many winters w/o abs $hit was AWESOME
TheGreenDutch
Users browsing this forum: Google [Bot] and 16 guests
