SolaraGuy.com • View topic - yet another timing belt list
Postby mettler » Mon Nov 05, 2012 6:49 pm
I searched the forums and got this for my list:
timing belt
tensioners
ac/alt belt
ps belt
spark plugs (6)
spark plug wires (6)
oil filter
thermo
thermo gasket
crank seal
water pump
water pump gasket
oil
_________________
do I need to get toyota specific tranny fluid? Do I need a tranny pan gasket? And, is there only one belt for the ps/ac/alt or is it two?
thanks
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Re: yet another timing belt list
Postby thenewguy » Tue Nov 06, 2012 3:53 am
It isn't required to get Toyota specific transmission fluid and you can easily buy some fluid from your local auto parts store; however, if I was in your shoes I would just go ahead and use the transmission fluid that's used for our car's to be absolutely safe. When in doubt, always follow the manufacturers suggestions for parts/fluids to ensure a long lasting happy car. :]
thenewguy
Postby DSM_Lara » Tue Nov 06, 2012 5:46 am
Since, your changing out your spark plugs might as well get those valve cover gaskets and all the other stuff to save you time and money (if your not doing it yourself).
Changing out All Gaskets
When I did my Timing belt
DSM_Lara
Postby Gregtrd » Tue Nov 06, 2012 9:38 am
Sounds like you dont have a clue of what youre doing, just take to
A shop and avoid the headaches.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby ToyoSolV6 » Tue Nov 06, 2012 1:39 pm
yup doing something like this is not fairly easy. If you havent done this type of work i wouldnt recomend you do it, but if you have. Go for it.
Users browsing this forum: Google [Bot] and 16 guests
