SolaraGuy.com • View topic - Fog lights not working
Postby Jahfalif1165 » Wed Nov 21, 2012 2:43 pm
One night it was working fine and the next night both of them stoped working i checked the fuse for the fogs and its fine i didnt have time to check the wireing yet
02 solara Se v6
Jahfalif1165
Re: Fog lights not working
Postby minig646 » Tue Dec 04, 2012 8:23 am
Check the relay too. If you don't know how, just turn the lights on and listen for a very quiet click. If it doesn't click, it's bad. If it clicks but they still don't come on, it could still be bad- swap it with a relay from a system that you know works and see if the fogs work then. I believe a large number of the relays are generic and interchangeable.
Also, don't rule out the possibility that both bulbs just burned out at the same time.
2000 MR2 Spyder- SOLD
2000 SEV6- TOTALED
1999 Supercharged SLE V6
minig646
Postby Jahfalif1165 » Sat Dec 08, 2012 8:44 pm
minig646 wrote:Check the relay too. If you don't know how, just turn the lights on and listen for a very quiet click. If it doesn't click, it's bad. If it clicks but they still don't come on, it could still be bad- swap it with a relay from a system that you know works and see if the fogs work then. I believe a large number of the relays are generic and interchangeable.
Its exactly what you said last. Both of the bulds went the same time
Jahfalif1165
Users browsing this forum: Google [Bot] and 16 guests
