SolaraGuy.com • View topic - AC Compressor Install
Postby thenewguy » Fri Dec 28, 2012 2:22 am
Has anyone done this before? Anything I should watch out for/replace while I'm in there? I replacing the AC Compressor and the belt for it.
-Thanks
-Thenewguy
thenewguy
Re: AC Compressor Install
Postby Eye8Pussies » Fri Jan 11, 2013 10:47 pm
kind of a late reply, but no, it's pretty straight forward. Be careful when letting the old freon out, and it's always best to replace the o-rings when disconnecting the lines, since you don't want any small leaks. Also, make sure you torque the line bolts correctly, as they will snap quite easily
Postby thenewguy » Sat Jan 12, 2013 2:23 am
thanks for the reply. I installed everything pretty quickly. Took me only an hour for the whole unistall/install. Anyone know how tight the alternator belt should be? I don't want anymore trouble from that area of the engine for a loong time haha
thenewguy
Users browsing this forum: Google [Bot] and 16 guests
