SolaraGuy.com • View topic - help on shocks and wheel hubs
Postby Solarachick » Fri Apr 12, 2013 8:02 pm
Hey guys can I get some tips on how to remove my rear wheel hub assembly and. Front shocks please ? :)
2002 SOLARA SLE V6 ,20" KMC WHEELS, FULL EXHAUST , LOWERED,TINTED WINDOWS,SMOKED TAILIGHTS,10K HIDS WITH MORE TO COME!!.
Solarachick
Re: help on shocks and wheel hubs
Postby Solarachick » Sat Apr 13, 2013 7:55 am
I guess nobody can help. =\
Solarachick
Postby Bostonlara » Sat Apr 13, 2013 8:48 am
Hey, front shocks are easy. Unbolt the stabilizer link where it attaches to the shock and push it to the right. Then unbolt the two larger bolts at the bottom of the shock where they connect to the steering knuckle. You'll need a socket and wrench because once it's loose it will spin. Btw these two are hard to break free if you have never touched them before. Last step is to unbolt the three nuts at the top of the Shock inside the engine bay. The. The shock will drop out and you're done!!! Install in reverse
building a 5.5psi S/C 3MZ 5spd with Meth, 305cc injectors, lite weight crank pulley, Apexi Neo, full exhaust & ypipe, CAI, TB spacer, knock upgrade, jims fuel upgrade, walbro 255, and much much much much more
Bostonlara
Postby PlateLunch » Sat Apr 13, 2013 10:01 am
Almost the same for the rears except you have to take the back seat out. I would suggest buying a chiltons or haynes manual as it will have detailed instructions for most of the more basic stuff like this, and they're only like $20-30. Also there are probably some tutorials in the DIY section, hope this helps :)
Edit: You will have to take a piece of strong wire and attach it to the top area and then attach it to your break caliper so caliper can hang. The wire should be short enough to let the caliper without screwing up either your break line or ABS sensor line. This is VERY important. Just wrap the wire through the strut hole and a bolt hole and then around your caliper. Good luck!
PlateLunch
Postby DSM_Lara » Sat Apr 13, 2013 3:53 pm
Disconnect your ABS line is a Must.
DSM_Lara
Postby Solarachick » Mon Apr 15, 2013 3:04 pm
Seems easy... my main thing is the rear hubs. I bought the complete assembly off ebay with the studs and all just have no clue on how to replace that =\
Solarachick
Postby Solarachick » Wed Apr 24, 2013 1:28 pm
Bump
Solarachick
Postby minig646 » Fri Apr 26, 2013 9:39 pm
Hubs are super easy on the rear. Once the brake disc is off, you'll see access holes that allow you to get to four 14mm bolts holding the hub on. Spin the the hub so the holes line up with the bolts and use a socket to remove the 4 bolts. Then it just pulls out, maybe with some persuasion.
2000 MR2 Spyder- SOLD
2000 SEV6- TOTALED
1999 Supercharged SLE V6
minig646
Postby Solarachick » Wed May 01, 2013 11:45 pm
Thank you so much guys, finally doing the labor this weekend
Solarachick
Users browsing this forum: Google [Bot] and 12 guests
