SolaraGuy.com • View topic - Heater fan won't work except on high
Postby SubjectAlpha » Sun Jan 26, 2014 12:42 pm
Recently noticed my heater/AC fan doesn't turn on except on the highest setting. Could this be a fuse problem? Is the high fan setting on a separate fuse?
SubjectAlpha
Re: Heater fan won't work except on high
Postby ASG14 » Mon Jan 27, 2014 7:16 am
Likelt the blower motor resistor.
ASG14
Postby SubjectAlpha » Mon Jan 27, 2014 8:51 am
Yeah, I think you're right. Saw some videos on where it is and how to replace. Just gotta decide if I'm ambitious enough to try to replace it myself.
SubjectAlpha
Postby ASG14 » Mon Jan 27, 2014 11:53 pm
It's fairly easy, even for a beginer.If you can change a headlight bulb, change an engine air filter, change a battery, change other bulbs, you can do this. It would be just a step above those things.
ASG14
Postby SubjectAlpha » Wed Apr 09, 2014 12:32 pm
Update: I did manage to fix it myself. Had to buy a right-angle screwdriver adapter to get that last screw out, and stripped it a little bit in the process. Didn't quite get it all the way screwed back in, but my A/C and heater is working again!
SubjectAlpha
