SolaraGuy.com • View topic - Air conditioning (AC) only blowing out heat
Postby udonoogen » Wed Oct 01, 2014 2:42 pm
I have a 1999 Toyota Solara SLE. I live in Southern California and thankfully it's been cooling down lately ... because my A/C is on the fritz. It was working fine a couple months ago and then intermittently until about two weeks ago. Now, it only blows out hot air. It doesn't matter if I turn the dial to "Max Cool" .... only hot air. The temperature sensor seems to be working okay ... because when it's ~80 degrees inside and I move it up to 80 and the climate control is on Auto, it will slow the blowing of the heat. But yeah ... I only get heat.
Any idea what is wrong? Do I need to bring it into the shop?
If it's just a fuse or a $40 recharge of freon, that's doable. I would prefer no shop, if possible.
1999 V6 SLE, Diamond White Pearl
udonoogen
Re: Air conditioning (AC) only blowing out heat
Postby TadS » Thu Oct 02, 2014 3:32 pm
Is the AC light flashing? Is the compressor making any weird noises? I'd start with a can of refrigerant, but if it's leaking it may just continue to do so. Make sure to get a gauge, as you don't want to add a leak to your problems if that isn't what it is.
TadS
Postby Gregtrd » Mon Oct 13, 2014 9:28 am
I'm in fontana if youre near by I can trouble shoot the problem.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
