SolaraGuy.com • View topic - vid of my camry at 7psi
Postby trd4life » Fri Oct 03, 2003 10:08 pm
http://fastattack.org/srtgurl/Gabe%...0SC%20Camry.wmv
its weird,last week i hit 14.0 at 103.5mph with a ****ty 2.3 60ft, i then added a 2.5" y pipe and a plasma booster thinking i would trap around 105mph at least but tonight i couldnt get any better than 14.2 at 101mph with a 2.3 60ft with the new mods. what could be going wrong?
Postby Hsakuragi » Fri Oct 03, 2003 11:01 pm
link not working man
Hsakuragi
Postby JoeB » Sat Oct 04, 2003 5:19 am
That's odd, so you're 60ft was the same but it dropped off at the top end. Sorry, I forgot your mods, have you opened up the intake with a short ram? I imagine the y-pipe came with a high-flow cat? It certainly sounds like an aftermarket exhaust. I'm guessing you already replaced the plugs with IK-22s? After that, wires then Plasma Booster. Have you checked the A/F mixture? Maybe with the y-pipe, you need to re-tune?
Maybe it's more fundamental. Unless the timing of the video is off, I see your brake lights at 9.0 secs. That would certainly decrease total time. :o I can't tell where the 1/4 mile is.
Thanks for the vid, cool stuff. In the ride wit me video, what's that noise when the boost lets off? My car doesn't make that noise. To get to the vid, I went to http://fastattack.org/srtgurl/ then went to the vid file you mentioned. I don't think the link liked the spaces. Rename the file with no spaces, use underscores instead. -JoeB
JoeB
Postby impactX » Sat Oct 04, 2003 5:02 pm
Got S-AFC?
Did you tune if after you install the new mods?
impactX
